Old 12-15-2006, 04:19 PM   #1
truckdude239
truckdude239's Avatar
new hei distributor
well after reading this post http://67-72chevytrucks.com/vboard/s...d.php?t=219568
i am thinking about buying one of his hei distributor http://cgi.ebay.com/ebaymotors/CHEVY...mZ260063342414
my question is the motor i am putting this in is a 305 with hei standart so can i use the same stock plug number gaped at .045?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-15-2006, 04:22 PM   #2
truckdude239
Re: new hei distributor
oh heres the plug i am thinking about running http://www.partsamerica.com/ProductD...pe=960&ptset=A
or ngk yr5 http://www.partsamerica.com/ProductD...pe=960&ptset=A
David fuller
2000 Tahoe 5.3l 378
Old 12-15-2006, 04:29 PM   #3
Southedisto
River life......
Southedisto's Avatar
I run the r45ts in mine.
Southedisto is offline   Reply With Quote
Old 12-15-2006, 04:37 PM   #4
71chevytruckguy
71chevytruckguy's Avatar
i got that same dist from that same guy and have had no problems. its been in my daily driver since may. i run ac delco r44ts plugs gaped at .40. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
