![]() Join Date: Oct 2006
60-62 hyd. clutch.
Has anyone come up with an economical idea on modifying the clutch master,when adding disc brakes? $499.00 for a brake/clutch combo is a bit steep.
Re: 60-62 hyd. clutch.
Havne't done mine yet, but I got the hydro set up off an 88-up truck with a remote clutch master. The cylinder is on the driver's side, which is 85ish to 91 OBS. I got a disc master/booster to go in, but no time to anything anymore. Buddy of mine put a 305, T-5, bell off an Astro, and clutch stuff for an 88-up, Im sure that we can get it to work in our stuff!!
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
thanks rat, any pics of it ?
No nothing yet. I might be able to take pics of what I have, but as far as install goes, who knows when that will be.
If you're referring to the CPP kit, yeah it's way overpriced. It just uses a generic Wilwood master cylinder for the clutch and a smaller vacuum booster mounted on the same bracket. You're really just paying for the bracket. I got a deal on a brand new '63-'66 CPP m.c. with booster and bought a seperate Wilwood m.c. from Summit for under $50. Here's a pic of a similar setup, not mine though.
Thanks kid that is nice !!
