Old 12-15-2006, 11:54 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
rearend fluid question
i was wanting to change my rearend gear fluid this weekend and i was wondering how much fluid it took and what the specifications are on the oil. its a 72 cheyenne with a 12 bolt rear.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 12-16-2006, 02:24 AM   #2
kwmech
Re: rearend fluid question
Buy 3 quarts, you may have a little extra left over
Old 12-16-2006, 06:35 AM   #3
JimKshortstep4x4
Capacity of the 12 bolt differential is 3 1/2 pints. 90 gear lube was originally used but there are other lubes available.
Jim
Old 12-16-2006, 08:39 AM   #4
70GMCer
70GMCer's Avatar
I bought 2 qts. and had a little left over......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-16-2006, 09:44 AM   #5
cdowns
cdowns's Avatar
2quarts is more than enough for a 12bolt rear spend the extra and go synthetic // don't over tighten the cover bots only about 10-15ftlbs are required
Old 12-16-2006, 02:05 PM   #6
crm318
crm318's Avatar
thanks for the info guys. ill get on it this weekend.
1972 Cheyenne
Old 12-16-2006, 03:14 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
crm check to see if it is a limited slip.Someone (hopefully) will chime in and tell you how to tell.Some limited slip rears require a special additive to work.I don't know much about it but I remember seeing some info in a historic post.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-16-2006, 03:32 PM   #8
crm318
crm318's Avatar
its an open 3.07. (wish i had a posi though)
1972 Cheyenne
