Super Trucker
i broke my shifter
ok, i got column shift 3 speed. it's been stiff to pull back in the 1 - R gate. i figured it just needed some lubing. not that big a deal.. nope.. something snapped inside my steering column. now the question is how do i fix this?
not sure if this is the right forum for this to be posted in.. so i just put it here. if a mod needs to move it.. go right ahead. and thanks.
American by birth, Southern by the grace of God. ".. you aint just whistlin' Dixie..." Rebel till I die |
Active Member
Re: i broke my shifter
Maybe the tip end of the lever broke off, pull the pin and slide the lever out
Never try to teach a pig to sing; it wastes your time and annoys the pig! ![]() ![]() My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
You broke the end of your shift lever off in column--see photo
http://www.truckandcarshop.com/trucks60_72/t60_049.html Remove lever pin (drive from bottom up)-pull lever out-reach in with needle nose pliers and remove broken piece. Spray WD-40 or oil in the slot where lever was removed. Install new or used lever. Under hood spray WD-40 in the place where the shift levers come out of column. It will not feel like you have a power assisted shift lever. (above advice carrys no warrenty)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
![]() Join Date: Nov 2006
I just got flash backs of when I was 16 and would have to get out of my '62 with a pry bar to unstick the gear shift with cars honking at me. I fixed it by putting in a 4 spd.
67-72 parts finder
yeah but if the shifter is not broke the tube in the column itself could be, 3 spd trucks are fun to drive once you get the trick of shifting it right so it doesn't hang up, some are worse than others especially when all the bushings and linkage gets wore out, instead of putting mine in the floor i'm just gonna redo the column shift with new bushings and such
![]() ![]() 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
Cantankerous Geezer
The cause is usually worn bushings where the levers are under the hood. They aren't kept lubed and wear. You can dismantle the column and replace them with bushings from the hardware store. I had one that would hang in first and required pulling the levers back into neutral. I let some other sucker live with it.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
The LuvShack Garage
Not to Hijack, but my old 70 stepper I had was converted to floor shift because
the housing snapped on the column and broke the entire mounting point, this was before I owned it, so they put in a Indy floor shifter, you know the cheap ass floor shifters from AZ, one night my truck driver buddies layed over at the plant and deceided to run down to the truck stop for some grub, I had since purchased another truck and had this one sitting at the plant, well off they go and as they went down the exit ramp to merge into traffic on the interstate it snapped off in their hands ![]() by the way, with a inline 6, and 4:10 gears stuck in 1st on the interstate ![]() it took them almost an hour to get back to the plant, normally 10 mintues, and they spent another hour welding the shifter back together so it would work ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() Join Date: Feb 2003
It would probably be cheaper to buy a GOOD used one here on the board.
I'm taking my 3 on the tree off today to insatll tilt colunm for automatic. Make me an offer and it's yours. PM me.
JD |
Super Trucker
so it could be the end of the shifter that broke off? just drive the pin out and pull the handle out? ok, anything going to happen when i pull that thing out? simple remove and replace operation? i've never really dealt with steering columns.
thanks for the offer truword.. PM sent. though i think i'm gonna let it sit till after the first of the year. i got a few other things i need to sort out with it. namely brakes and suspension bushings. i might even go as far as putting PS in it. this is my daily driver after all. my good friend suggested i just pull out my 3speed and put a th350 that i have laying around in it. and thanks for all the replys the more i know the better off i think i'll be.
American by birth, Southern by the grace of God. ".. you aint just whistlin' Dixie..." Rebel till I die Last edited by blacktruck; 12-16-2006 at 03:31 PM. |
