Old 12-16-2006, 04:59 AM   #1
71C-10DAD
71C-10DAD's Avatar
What is wrong my truck.
Whenn i hit it to get on the highway or just punch it in town to show them ford guys whose boss. It is like stalling out on me. Like it is starving for gas or that it is getting to much. Spitting and sputtering all the way up the onramp. What do i do. I wish some of you guys that are always so helpful lived close by. By the way in my birthday post i said that i may have to sell it well my wife told me otherwise. She said " We will get by there isn't any reason for you to give up that truck." GOD I LOVE THAT WOMAN!! Then she starts handing my my birthday gifts all of which are tools for working on my truck.
And here is a pic of the wheels i am buying tell me what you guys think...
1971 Chevy C-10 .
71C-10DAD is offline   Reply With Quote
Old 12-16-2006, 06:17 AM   #2
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: What is wrong my truck.
feul supply or timing, i would start with timing.
trkklr77 is offline   Reply With Quote
Old 12-16-2006, 10:06 AM   #3
manimal
manimal's Avatar
Check your accelerator pump,make sure you ahve a "good" SQUIRT of fuel into the carb and not just dribbles.check this with the engine OFF.
manimal is offline   Reply With Quote
Old 12-16-2006, 10:57 AM   #4
mrein3
mrein3's Avatar
The above advice is good however I would do a compression test. It may be time for a valve job. Check compression in all 8 holes.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-16-2006, 11:02 AM   #5
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
i got and 84 that will do the same thing,,but it likes to eat the fuel filters,,still have not figured out why,,but about once a year it will just collapse the fuel filter up in the carb...i'd check the fuel filter first..
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 12-16-2006, 11:50 AM   #6
ratrod67
ratrod67's Avatar
Check the vacuum advance on the carb.
ratrod67 is offline   Reply With Quote
Old 12-16-2006, 11:57 AM   #7
classicchev
classicchev's Avatar
Im big on fuel filters, check them first, it is the simpliest. For those guys who havent driven your trucks for a long time, it may be wise to flush out your tank. As gas evaporates, it leaves a clear lacquer on the side of the tank, and guess where it ends up at. you can not see the stuff in the filter, but try to blow though it.
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 12-16-2006, 12:17 PM   #8
cdowns
cdowns's Avatar
fuel filters both at the carb and IN THE TANK
collapsed dryrotted rubber fuel lines
improper gap to plugs or points
old sparkplug wires
leaking dryrotted vaccume lines
improper timing/ streached timing chain
dirty air filter
malfunctioning choke
a few things to check
Old 12-16-2006, 03:25 PM   #9
71C-10DAD
71C-10DAD's Avatar
supposedly when i got the truck the otor had ust been rebuilt. As far as checking compression and that other stuff you guys mentioned. I am a newb when it comes to this mechanic type stuff pictures or a decription would be very helpful.
1971 Chevy C-10 .
Old 12-16-2006, 03:26 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
My 6 did that until I replace the vacuum advance in the distributor.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-17-2006, 12:23 AM   #11
myoldchev
Junior Member
myoldchev's Avatar
Those wheels look slick. Where are you getting them from, if you don't mind my asking?
DAN
69 CUSTOM 10 LWB:
myoldchev is offline   Reply With Quote
Old 12-17-2006, 12:44 AM   #12
pritch
pritch's Avatar
This is really easy, but you need a compression tester. I havn't bought one in ages, but (and correct me) $20-$25 bucks ought to get a decent one. There are two types, one that threads into the sparkplug hole, and the other has a rubber kind of a nozzle looking thing on the end that you hold tightly into the sparkplug hole. This type requires either a helper or a remote started button. With either type, the point is to have the motor turn over a few times and pump up guage on the tester. Whichever type you get, there would be instructions with it on how to use it.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 12-17-2006, 12:44 AM   #13
CPNEJR
CPNEJR's Avatar
you could also have the smaller sending units that were for the sixes so when you try and gun it it will starve its self of gas because the line is too small
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 12-17-2006, 12:53 AM   #14
blacktruck
Super Trucker
what kind of carb are you running? i'd check for vacuum leaks and proper float adjustment after you've done the aforementioned things. good luck.
American by birth, Southern by the grace of God.
".. you aint just whistlin' Dixie..."
Rebel till I die
blacktruck is offline   Reply With Quote
Old 12-17-2006, 02:19 AM   #15
Ron 586
RIP Mr Ron
Ron 586's Avatar
Call me an old fool but I would spend my money on getting that truck running good and making sure it's safe to drive before putting dress up items on it. You'll have plenty of time to make it pretty after you are happy with the way it runs.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 12-17-2006, 08:48 AM   #16
68C15
blood type; Retumbo
68C15's Avatar
does this still have points? hint-hint
68C15 is offline   Reply With Quote
