Old 12-16-2006, 05:32 PM   #1
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
0PSI, oil pressure! Help!
Just got done changing my oil, and putting a new set of autometer gauges in my truck, the factory oil pressure gauge never worked, and now the new autometer gauge reads 0psi of pressure aswell.
The truck has 5 quarts of mobil 1 and a brand new filter.
Common sense says, that with no oil pressure, after the truck was running for 10mins, it should've destroyed the bearings and ground to a halt.
Any idea's on my problem here?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 12-16-2006, 05:59 PM   #2
lost wages
lost wages's Avatar
Re: 0PSI, oil pressure! Help!
electric gauges? if so dont use any sealant or teflon tape on the sending unit or adapter for the sending unit in the block. needs a good ground to work.
lost wages is offline   Reply With Quote
Old 12-16-2006, 06:00 PM   #3
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Mechanical.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 12-16-2006, 06:00 PM   #4
shortbed70
shortbed70's Avatar
where does your tube go into the block at? If it goes in the back of the block it might have crud buildup under the hole and not allowing oil through.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-16-2006, 06:06 PM   #5
neonlarry
neonlarry's Avatar
Did you check for kinks in the copper tubing? maybe thats why your factory OP gauge did not work.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-16-2006, 06:46 PM   #6
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
I figure something has to be wrong with the gauge or the feed, as if the truck was running for 5-10mins without totally fragging the motor it should be fine, right?
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 12-16-2006, 07:11 PM   #7
cdowns
cdowns's Avatar
take the sending unit out of the block turn on the engine and see if you've got a squirter, then install sender see if it squirts out of there then hook up tubing and see if it squirts out of that finally hook up line to gauge and if it squirted all along the path and the gauge dont move you've got a bad gauge
Old 12-17-2006, 12:24 AM   #8
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Chances are, if your old gauge didn't work and your new gauge doesn't work, you've got a problem with the feed line for the gauge. This is pretty common for these trucks. I would guess there is nothing wrong with your old gauge either. As some others have said, check for kinks or, just go ahead and change the line... It is probably the source of your trouble.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 12-18-2006, 08:02 PM   #9
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
The bad thing is, the line is brand new.
There are spots of oil in the line up until the line enters the firewall, so it may verywell be kinked where it enters the cabin from the firewall.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
