12-16-2006, 06:25 PM | #1 |
its all about the +6 inches
lets talk flip kits
Flip kits, to lower the rear of a leaf rear... how does this work, and is a real kit needed? Am I able to simply cut off my mounts, and reweld them to the other side of the axle, and then use shackles to raise it enough to keep the axle off the frame?
What else do I need to know? Last edited by Longhorn Man; 12-17-2006 at 10:35 AM. |
12-16-2006, 07:12 PM | #2 |
Re: lets talk flip kits
The only issue you may have is on a flip kit the axle is offset to correct pinion angle but if its just a driver I wouldnt worry much about it. Ive got installed flip kit pics I can post later if you want them...
12-16-2006, 07:33 PM | #3 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 12-16-2006 at 07:35 PM. |
12-16-2006, 09:39 PM | #4 |
The LuvShack Garage
Go for it Andy
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
12-16-2006, 09:42 PM | #5 |
12-17-2006, 12:19 AM | #6 | |
Chevy Truck Addict
A flip should get you about 5-6 inches of drop. Your comment about shackles is confusing though. After the flip, there will be no way of bringing the truck back up other than re-arching the springs. Adding a taller-than-stock shackle will bring the truck down even lower and move the axle closer to the frame.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
12-17-2006, 10:37 AM | #7 |
Al, that is in fact what I am thinking about. I would like to keep my one ton springs so I still have a good pay load, but sick of the nose bleeds from sitting so high.
C-10Driver, adding blocks would do as you mention, but shackles, from the frame to the spring, would raise the back of the truck. I don't think I want 5 to 6 inches, and that is why I was thinking of the shackles to bring it back up... I think maybe 3 or 4 at the most, just a mild drop. What about c-notch... will this be an issue? Will I want some kind of a bumper to keep the exle off the frame? |
12-17-2006, 11:55 AM | #8 |
the way that the shackles & hangers are laid out from the factory, a longer shackle will give you a drop. I think a flip would be way more drop than you would want , but you should get approx 2" with a shackle, & you could also take the perches for the front spring eyes off the frame, & move them up to give a little more drop. You need to mark & redrill the frame for the brackets, & be sure to use some hardware to replace those rivets! I did a flip on mine, & tossed all but the top 4 leafs, but it sat the rear too low. my fix was to knock off all 4 spring hangers & move them DOWN on the frame a couple inches , to raise the truck back up a tad. I figure approx 5 1/2" on my rear drop, & I have 2 1/2-2 3/4" clearance tween the rails & the rear diff (no notch). this is not a problem for my useage.....but I dont do any hauling with the old truck. You can get a good idea on a flip drop, just measure the thickness of the spring stack(that 1 ton stack is plenty stought), so Im guessin you will have better luck with shackles & hangers if you need a 3-4 " drop...... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-17-2006, 01:41 PM | #9 |
sweet.
I guess I shoulda taken a good look first... I remember on an old square body poS-10 we used shackles to bring one back up a bit. I'll have to look into this a bit better. Even though I use my truck as a huge friggen car, I do load it down pretty good from time to time, (some of you may rememberr how I actually used my last car...as a truck) So I like the idea of having the one ton springs under there still, and if I can keep the overloads, that's an added plus. Up front, one coil chopped off is good for about 2 inche... is that right? That's what I remember, but my memory isn't what it was. (and the sad part is I'm still only 32) |
12-17-2006, 03:25 PM | #10 |
Yes, you should see 2 -2 1/2" drop for 1 full ring on the fronts. best of luck, L
