12-16-2006, 08:50 PM | #1 |
Active Member
Problem!
Well I was removing the gas tank from the my 67' and darn if that was the only thing that was holding the back of the cab up. Most people would just junk the cab. Not me, I'm one of those guys that doesn't have enough brain cells left and wants to try to fix this little problem.
My question, what is the mesurement from the rear cab mount to the roof? I currently have it braced up and some of the patch panels cut. I just need to know how high to make my roof, a poor mans body drop... thanks, Paul
'67 Chevy LWB (Running) '67 Chevy LWB (Not Running) '70 Chevy LWB (In Pieces) '72 Chevy LWB (In Pieces) |
12-16-2006, 10:01 PM | #2 |
The Older Generation
Re: Problem!
Paul,
It might be kind of tough measuring it but I will give it a shot in the morning. LockDoc
12-16-2006, 10:49 PM | #3 |
Active Member
Re: Problem!
Thanks, I agree with your signature.
Paul
12-16-2006, 11:37 PM | #4 |
laying low
Re: Problem!
You could bolt the tank back in and then measure yours.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-16-2006, 11:43 PM | #5 |
village idiot
Re: Problem!
12-16-2006, 11:56 PM | #6 |
Active Member
Re: Problem!
Laugh it up! You would think that would be a good idea.
12-16-2006, 11:57 PM | #7 |
village idiot
Re: Problem!
I'm worried about looking under mine now
12-17-2006, 12:06 AM | #8 |
Fabricate till you "puke"
Re: Problem!
Damn, my tank is under the bed.....I wonder whats holdin the rear of the cab up? (YIKES!) I guess my thoughts are with Boog......bolt the tank back in , & go from there. I could measure mine, but it wont help.....the top has been "squashed " a tad L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-17-2006, 12:46 PM | #9 |
Re: Problem!
Booth,
I measured from the plate where the body mount bolt comes through the floor. From that plate to the top flange of the rear window opening is 40 1/4", and from that plate to the seam in the inner roof panel is.... 44 3/8". Hope you can use those. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-17-2006 at 12:47 PM. |
12-17-2006, 12:50 PM | #10 |
Active Member
Re: Problem!
Thank you very much
12-17-2006, 07:00 PM | #11 |
Re: Problem!
No problem.... LockDoc
