Old 12-17-2006, 12:17 AM   #1
skokie
skokie's Avatar
2 1/2 ramhorn exhaust routing
For those running the 2 1/2 ram horns did you have clearance issues with the straight dump? How did you not hit the starter?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-17-2006, 12:35 AM   #2
CPNEJR
CPNEJR's Avatar
Re: 2 1/2 ramhorn exhaust routing
please correct me if i am wrong but the straight dump ram horns are for 4 wheel drives only and don't work on 2 wheel drive trucks
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 12-17-2006, 01:12 AM   #3
skokie
skokie's Avatar
Yep you are right but I have seen folks put them on 4x2s.
68 build thread
Old 12-17-2006, 03:28 AM   #4
dave2953
Dave's not here, man
dave2953's Avatar
My truck has the swept back version of the ram horns and the driver's side pipe comes pretty close to the starter but does clear it. I haven't had any trouble with heat soak since I swapped to duals last December. I'm not sure how much different the clearance is on the 4x4 versions.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 12-17-2006, 09:20 AM   #5
uncle
I ran them on a 2wd truck and used a later model starter(90 truck). It was still tight. I think if you ran the V-8 in the 6 banger location, it would give you more room.
uncle is offline   Reply With Quote
