Old 08-20-2002, 10:55 PM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Does anybody make clear bumper lights for a 72?
Well, does anybody?
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 08-20-2002, 11:32 PM   #2
Benrs86
Benrs86's Avatar
ive never seen them, but im sure you could make your own with some time, and save some moeny while your at it. use some lucite with the ceiling light plastic to diffuse it or just some plexiglass with a bulb behind it would work. if you sand the plexiglass then you cant see the bulb behind it, but you can see light through it. good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
