dimensions for cab dolly?
I would like to build a rig to hold my cab and roll it around the shop (Cab dolly?) but need the dimensions of the frame mounts before I pull it off. Does anyone have these or a bare frame. I basically need measurements of all frame mounts under the cab (distance between and elevation differences). thanks...
Re: dimensions for cab dolly?
![]() ![]() Join Date: Jul 2002
IO did a crude one from 2x4's and it has worked for me. This may give you the rough dimensions you need.
Mine made the cab a little high for some things, so I would use the recommended height measurement.
![]() Join Date: Feb 2004
Hey, that seems pretty cheap enought to build is it sturdy?
How do you keep it from sliding off?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
thanks for the reply's .
I need one that the cab can bolt onto so I can add it to a rotating assy. Something like Rokcrln's but like a stretcher version so that I can hook up each end and then rotate it 360 degrees. I really just need the body mount measurements I guess... |
![]() Join Date: Nov 2006
the cheapst and best way to make it is to take a stock frame and cut it off in front of front cab mounts and same with rear mounts, i,d weld a x-member between the frame rails to stiffen it ft. & back. weld dolly wheels to bottom at the height you want cab to be. jusy my o2.
bob |
72armyswbtruck...the weight of the cab keeps it in place real well. I also could have put some lag scrwes in the mount holes into the wood if I wanted too. I moved mine all over for 6 months or so and not a problem. Right now I am using it as a stand for my fleet bed.
