Old 12-17-2006, 10:41 PM   #1
Jerry8168
Jerry8168's Avatar
door poppers on my truck
i was wondering what is the process of putting door poppers on my truck and how hard is it and which one would be the best one to go with?
Jerry8168 is offline   Reply With Quote
Old 12-18-2006, 11:15 AM   #2
slepysal
slepysal's Avatar
Re: door poppers on my truck
are you talking about "shaved doors?" They are fairly easy the hardest part is covering the hole.There are three types , The old cable style, the push button style, and The remote type. I have used all 3 and I realy like the remote type.
I have used "Auto Loc " and have had good luck with them
slepysal is offline   Reply With Quote
Old 12-21-2006, 06:26 PM   #3
Rural Hauler
Rural Hauler's Avatar
I just installed the autoloc remote in the drivers side to test it out. I haven't installed the poppers because the door opens enough to grab it. When looking for and area to install the poppers, the bottom right area looked like a good candidate. Good luck with your project.
Rural Hauler is offline   Reply With Quote
Old 01-07-2007, 06:21 PM   #4
Pitts1e
Pitts1e's Avatar
I just finished installing some on my 67. I went with the Autoloc billet plunger type. I originally tried the bottom right corner but it was actually putting a bit of a twist in the door when it was fully closed. So I moved them to the hinge area. I basically drilled a hole big enough for the plunger where the "4th" bolt would be. I then had to fab a little bracket that was welded to the cab so that the plunger was almost fully depressed when the door was closed. It worked out to be about a 1/2". The doors will now pop out about 1.5 ft. I also cut the original hinges out and installed a bearclaw latch which helps to pop the doot as well. I can post some pics if you are interested.
Cheers
Will this thing ever get done!!
Pitts1e is offline   Reply With Quote
