Dave's not here, man
Am I Screwed?
For some time my truck has been making a "knocking" noise. After some searching, I came to the conclusion that my flexplate may be cracked. (I had already looked at the bottom end to no avail) I got the first 4 bolts out without incident, and then these two hookers started to round off. Any ideas on what I can do to fix this?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 12-17-2006 at 11:57 PM. |
turbo enthusiast
Re: Am I Screwed?
I have no idea how to help you, but I would sure like to see pics of that '62 mini cooper panel
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
Re: Am I Screwed?
Here you go...
http://i108.photobucket.com/albums/n...2953/Mini3.jpg http://i108.photobucket.com/albums/n...2953/Mini2.jpg http://i108.photobucket.com/albums/n...2953/Mini1.jpg http://i108.photobucket.com/albums/n...2953/Mini4.jpg
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 12-18-2006 at 12:31 AM. |
RIP Mr Ron
![]() Join Date: Dec 2005
Re: Am I Screwed?
Take a big shop hammer and make sure you hit it flat head on. (don't try to knock the crank out of the block) That will serve two purposes, It will jar the threads loose and it will swell the head of the bolt so that the wrench might not slip. Make sure and use a 6 point socket or wrench on it that fits tight. Hope this helps as I would not drive back to where you live for the truck. Made it home with old blue at 10:30 pm.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
#5 | |
Re: Am I Screwed?
Or go to Autozone....spend a few dollars and buy a stripped bolt removing tool. I used one a few years ago and it worked like a charm.
#6 | |
The Older Generation
Re: Am I Screwed?
![]() LockDoc
turbo enthusiast
Re: Am I Screwed?
Drop a big block in that mini and you'll have a screamer!
Re: Am I Screwed?
I was using a six point socket, but the problem was that I didn't have a 14mm in a 1/2" drive. I used a reducer on the 1/2" ratchet to accept a 3/8" socket and was having trouble keeping it square on the bolt. That coupled with the fact that these bolts were severely overtightened led to the heads starting to round off. Originally I slid the trans. back away from the motor, but since I needed more room to work I had to pull the trans. Do you think I may be able to use your hammer/socket method and try an impact? Not sure if they would help or hinder? (BTW, it was a WHORE to get the trans. out with the truck on jackstands
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 12-18-2006 at 01:57 AM. |
![]() Join Date: Sep 2005
Re: Am I Screwed?
striped bolt remover they don't cost to much
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
67-72 parts finder
Re: Am I Screwed?
man those can be a pain in the rear i had to take a hammer and chisel to two bolts in the crank of one of my old 350s that held on the flexplate i'd try the impact because the jarring of it might help you if it rounds off anymore you're still ok just use the hammer and chisel like i did now remember your not tryin to chisel the bolt head off but just trying to break it loose hope i've been helpful
![]() ![]() 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
Born Psycho
![]() Join Date: Feb 2001
weld a deep nut to whats left of the bolt, the heat from welding will help if the bolt has loctite on it. we do it at work all the time on 3.0 nissan motors, they break exhaust manifold bolts flush with the head--aluminum head
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Parts and more parts
Re: Am I Screwed?
I agree with the welding of a nut to the bolt. The heat will help you at this point.
#13 |
Re: Am I Screwed?
"Bolt out" from Sears or some such tool. Kinda pricy for a set but you know what they say, "Good, fast, cheap, you can only pick 2."
#14 |
Re: Am I Screwed?
I got the Irwin Bolt-Grip sockets. They work so damn good, it's funny. I spent about $45 for the full set, but they are SAE/Metric, so you only need the set.
#15 |
Re: Am I Screwed?
I tried to use a "bolt removal" tool this morning. It was biting in to the bolt just fine, but I couldn't get the bolt to budge. I'm 6'2" and 200lbs. and was giving all the @ss I could muster. I don't have a welder and I'm not certain if I can get one to try the welded nut suggestions. I just recently tried to use a chisel, but that didn't work either. It did a good job of hosing one of the bolts. I soaked them with PB Blaster before I started but that obviously didn't have much affect. I'm at a loss.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
#16 |
Questionable
Re: Am I Screwed?
Go to your local store and get one of those "Gator Grip" sockets. Hell, looks like they even sell them at Walgreens:
http://www.walgreens.com/store/produ...ec=frgl_602860 Supposed to work like a champ from what I've heard, but I've never used one. If it won't budge, try applying heat.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#17 |
![]() Join Date: Sep 2002
Re: Am I Screwed?
Go to auto zone and buy a set of stripped bolt removers . I bought a set and they work great. The hammer method is the right idea.
Certifiably crazy person |
#18 |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Am I Screwed?
Another trick is to use a (box end wrench) instead of a socket. Get a 6 sided wrench drive it on the head of the bolt, then while applying pressure to hold the wrench on the bolt use a hammer to tap the wrench in the loosen direction. This will act as an impact and the angle is less for wobble over.
#19 |
Re: Am I Screwed?
Is this motor out of the vehicle? If so, put it in the back of a truck and take it to a shop that has the welder and do it there.
#20 |
Re: Am I Screwed?
The engine is still installed. I have the trans. pulled out (the truck is on jack stands) so my work space is limited.
#21 |
Re: Am I Screwed?
Did you heat the flange up when you used the bolt removal tool? You might want to go in there with a propane torch and heat up the flange around the bolts then try the removal tool again.
Enjoying life again. Time to get those big blocks rolling. |
#22 |
![]() ![]() Join Date: Jul 2002
Re: Am I Screwed?
In my case, I normally switch from serious English words to Japanese or Russian words. The Russian sounds more forceful. My dad always said you have to know how to talk to some cars.
![]() GOOD LUCK with it I ended up with one that stubborn many mons ago and didn't have a welder, so I cut the bolt head off, then slowily drilled it out unutl there wasn't must bolt left, then used a stud remover.
#23 |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Re: Am I Screwed?
That's alot of good ideas. Here is one that might work. A long six point box end wrench hammered on to the bolt head with the end of the wrench wrapped in a rag where your hand is going to hold it and at the same time use a propane torch with map gas and heat the bolt while applying pressure. Just a thought.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
#24 | |
![]() Join Date: Nov 2005
Re: Am I Screwed?
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts! |
#25 |
Re: Am I Screwed?
I gave up the jackstand thing years ago and purchased my own two post lift. I know where there is a 7000 lb lift for sale, right now, here in good old Kansas. These things are great.
