Old 12-18-2006, 08:42 AM   #1
Misstur_big
Junior Member
Misstur_big's Avatar
81 Speedo issue
My mother has a 81 stepside GMC 350 350 trans.
She was involved in an accident and bent the housing on the rear end. They replaced it with a used one. It had a pretty high road gear that I am not sure of the ratio. They replaced it with a 3.73. The truck still has stock tires that I think are 265/70R/15's. Does anyone know what speedo gears go in it for this set up?
Misstur_big is offline   Reply With Quote
Old 12-18-2006, 12:46 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 81 Speedo issue
If you go to the dealer, they still have the older books with the speedo gears listed for each tranny/rear end set up. I have most of the numbers copied from their books, but the 350 tranny stuff that I have ends at 3.42 gearing, but they show a #6261782 (9 tooth green color) gear as the drive with a #3987922 (22 tooth gray colored) gear for that combo. These mount with the #6273218 adapter (housing mount piece.) As I said you will have to go to the GM parts counter and ask them to look into the older parts books for the truck/tranny combos. (Speedometer Gear Charts)
When I changed out my rear end to 3.73 gears from the 3.42 gears, all I had to change was the driven gear on the speedo. That was on a 700 R4 tranny.
3.73 gears on a 350 tranny makes for a low geared stump puller, Gas mileage went to heck--
piecesparts is offline   Reply With Quote
Old 12-21-2006, 01:38 AM   #3
jimfulco
Re: 81 Speedo issue
I don't know right off hand, but http://novaresource.org/speedo.htm has a formula that uses gear ratio and tire diameter to help you find an appropriate gear set.
http://tciauto.com/Products/TechInfo/speedo_gears.asp has a tire diameter calculator.
If she'd rather have a highway gear, call me at 424-5170.
jimfulco is offline   Reply With Quote
Old 12-21-2006, 10:47 AM   #4
ScottH
ScottH's Avatar
Re: 81 Speedo issue
Check this out -
http://www.transmissioncenter.net/sp...n_______va.htm
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
