Old 12-18-2006, 08:27 PM   #1
pimperout
pimperout's Avatar
tranny seal
i noticed the other day while changing my oil that i had sprung a leak in the tail shaft of my tranny where the drive shaft comes out i was just wondering if mabe you guys could give me some pointers on how to replace this seal i got a picture so you can see where im talkin about http://i147.photobucket.com/albums/r...mytruck056.jpg
pimperout is offline   Reply With Quote
Old 12-18-2006, 08:36 PM   #2
arkracing
Weekend Warrior
Re: tranny seal
#1. Take the drive shaft out.
#2. Small Screwdiver or Small Chisel & Hammer
#3. "Pry" it out with the screwdriver or chisel & hammer
#4. Install New seal - make sure you get it square in there and "hammer" all the way around the seal while it is going in - so you don't bend the seal trying to hammer on one side of it.
It's not that bad to do - the seal might be a little stubbor coming out - but once you collapse one side of the seal you can pry it out or use some pliers to yank on it.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 12-18-2006, 08:37 PM   #3
pimperout
pimperout's Avatar
Re: tranny seal
oh man thats easy and by the way thanks for the quick reply
Old 12-18-2006, 08:41 PM   #4
Sweet72
Sweet72's Avatar
Re: tranny seal
Leaks at the tailshaft are usually caused by a worn bushing. A transmission shop will replace only the rear bushing and seal if you take only the tailshaft in. The four bolts are all that hold it in place. You can replace the seal yourself by dropping the driveshaft...Remove U bolts on diff. yoke, then remove two bolts holding center bearing, slide slip yoke out of trans. Have a pan ready to catch the fluid. Carefully pry the old seal out, and I do mean careful, I've heard of guys breaking the aluminum tailshaft housings by getting too rough. tap a new seal in place and reinstall driveshaft in reverse order of disassembly. Top off the fluid. The seal may leak again soon if the bushing I'm talking about is real sloppy.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-18-2006, 08:46 PM   #5
pimperout
pimperout's Avatar
Re: tranny seal
oky doky thanks man
Old 12-18-2006, 09:07 PM   #6
john
member #16
john's Avatar
Re: tranny seal
You will get a minimal loss of fluid if you jack up rear axle high enough to do the job and leave the front down.
john is offline   Reply With Quote
Old 12-20-2006, 02:09 AM   #7
pimperout
pimperout's Avatar
Re: tranny seal
man i love this forum so much info thanks
Old 12-20-2006, 02:14 AM   #8
brak
brak's Avatar
Re: tranny seal
as with most seals, using a large socket to drive it in will help keep it square.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
