exaust on a bagged 68 sb
i had the exaust run where it crossed under the frame and when i lowered it it hits on the ground so i cut in and thinking of putting it under the cab or above trailing arms any pics or suggestions i have mid length headers into duals 2.5
Dave's not here, man
Re: exaust on a bagged 68 sb
How much did you drop the truck? I have my exhaust pipes run just inside the frame rails and they exit in front of the rear wheels. The pipes sit a bit lower than than the frames rails and my truck has a ~4/5 drop with no clearance problems.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Its On Bags It Lays The Cross Memer Up Front
I built mine as I went with the idea of 3" duel all the way out back. My trany x member has raised areas for the pipes to pass and so does the trailing arm x member. From their it goes over the trailing arms and the x member above the axel is notched and reinforced so th eexhaust clears that as well then dumps over the diff and comes out in both rear corners. Sorry I don't have and competed pics to show yet. Also my front arms lay out and my rear license plate also lays on the ground. The bed floor is raised up 6" to help with all this. Here are a few pics I had that will give you an idea.
Kevin LFD Inc. |
Kevin,
i have been following your work... and i am impressed... keep it up.. what engine is that.. and what year model? Rich |
#6 | |
Insert Title Here
I love the way you angled the back of the bed floor down like that... Im going to have to do that when I lay mine out
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
