![]() Join Date: Apr 2005
Question on replacing inner and outer door bottoms
I'm fixing a set of doors for a friend (they look like swiss cheese at the bottom) and I'm trying to figure out the best way to do it. I tried the search function but didn't really see anything that helped. My biggest question is, which part do you replace first - inner or outer? Thanks in advance.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: Jun 2002
Re: Question on replacing inner and outer door bottoms
Rob, good question, I have been looking at mine and was wondering the same thing.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
![]() Join Date: Nov 2004
Never done this before, but thought about it.... I would probably replace the inner first. Peel back the skin on the door where the inner will be replaced and modify the new inner if need be. The outer should then fit (hopefully) nicely over the new door bottom.
my 2 cents
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
![]() Join Date: May 2006
If you have the Tristar replacement panels take some really good measurements before you cut off anything, because they're not quite the same as the original door.
I cut out the inner door first and started from there. I guess the hardest part was trying to cut and fit the inner piece as to maintain the original curvature of the door and not have a lot of big gaps to weld up. Also use a bead of sealant around the door bottom when you put the outer door skin on. Also bend the door skin outer flange slow and in small steps to keep from warping it. If I had it to do over, I would have bought the complete door. |
Rusty, you did a great job, but you are right, it looks like a lot of work...
Rg
"If you have the Tristar replacement panels take some really good measurements before you cut off anything, because they're not quite the same as the original door.
I cut out the inner door first and started from there. I guess the hardest part was trying to cut and fit the inner piece as to maintain the original curvature of the door and not have a lot of big gaps to weld up. Also use a bead of sealant around the door bottom when you put the outer door skin on. Also bend the door skin outer flange slow and in small steps to keep from warping it. If I had it to do over, I would have bought the complete door." Thanks for the info Rusty. I agree about buying new doors, however, my buddy didn't have the cash to buy new ones, $500 vs $75 (he has a 66) was the determining factor.
#7 | |
Do you have any drain holes on the door bottoms? Factory doors have two drain holes, without them you're doors will rot pretty quickly. If they're there, sweet, if not, just givin' ya a "heads up." ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 12-19-2006 at 12:24 PM. |
#8 | |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
I replaced my inner & outer door bottoms, but I cut about 5" out, just enough to get rid of the rust. Before I started cutting the old metal out, I took several measurements and put everything back to those dimensions. Everything fitted up well and I did cut drain holes in the bottom, as close to the originals as possible. All in all they turned out very well and I'm glad I did it, but it was a lot of work.
While I had the bottoms open, I sandblasted, etched and epoxy primed the inside of the doors. Then I sealed the seams with 3-M seam sealer. I then sprayed a coat of Gravitex on the insides of the doors after they were completed. The reward came when i fitted them up and they fit perfectly.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
Just wanted to thank everyone for all the tips. Here's what I got done in about 2 hours tonight. I got the inner tacked in and the outer fitted with the door on the truck. Figured that was the best way to make the body lines match. Just a little more cutting and then it all can be welded up. This was the worst door, hopefully other side will go as quick.
Great work!
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
computer illiterate
i did mine the same way it was fairly easy.
72 2wd blazer 72 swb 4x4 |
