Old 12-19-2006, 11:46 AM   #1
phase_one
problem with fuel or carb set up
I recently switched from points to a HEI dist. I have a 250 and used the info off of this board. It went well except i can't get the truck to run If i poor gas in the carb it will start up and run until the gas is used up. I thought of a fuel line problem. I took the tank out and used my air compresser to clean out the fuel line, sending unit and fuel pump, I even replaced the fuel filter. The carb was a rebuild from auto zone and worked when I installed it. The problem is there is no fuel when the gas pedel is pressed. Is the change from points to HEI affecting the vacum lines? Any help would be appreciated.
11 Surbaban
70 C 10
still in progress
phase_one is offline   Reply With Quote
Old 12-19-2006, 02:02 PM   #2
cdowns
cdowns's Avatar
Re: problem with fuel or carb set up
disconnect fuel ine from carb crank over engine see if its pumping gas if not// you might have an empty fuel tank OR bad fuel pump OR clogged or broken fuel line check under the pass side cab theres a short piece of rubber hose it may be dryrotted and or kinked
Old 12-19-2006, 02:04 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The HEI swap should'nt have had any effect on the fuel and if it will run when you pour gas in the carb, I'd pull the line loose at the carb and see if fuel is making to there, if so then you have a float problem in the carb otherwise I'd say replace the fuel pump.
sneakysnake is offline   Reply With Quote
Old 12-20-2006, 06:24 PM   #4
phase_one
How would I know if the fuel sending unit isn't sending fuel to the fuel pump?
11 Surbaban
70 C 10
still in progress
Old 12-20-2006, 07:07 PM   #5
rage'nrat638
rage'nrat638's Avatar
the fuel tank sending unit just reads the fuel level in the tank..and the voltage is read at the fuel gauge in your dash...has nothing to do with your carb not getting gas...hope you get it worked out
rage'nrat638 is offline   Reply With Quote
Old 12-20-2006, 08:10 PM   #6
corn
Does it by chance have an electric fuel pump that got disconnected when you hooked up the distributor?
corn is offline   Reply With Quote
Old 12-20-2006, 10:52 PM   #7
FarmTruk
In Memoriam...
FarmTruk's Avatar
I'd say probably...
1...bad rebuilt carb. Float stuck at top.
2...bad fuel pump.
I've had both issues happen to my stuff in the past. Luckily, they did not happen at the same time.
If by chance there is an electric fuel pump there, compressed air "should" not make it to the fuel tank, as there is a check valve in most I've seen that will prevent backflow. Did you hear the air "gurgling" in the tank?
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 12-21-2006, 01:42 PM   #8
phase_one
It is a mechanical fuel pump. the pump is not working. I will replace and see where i stand.
11 Surbaban
70 C 10
still in progress
Old 12-21-2006, 04:32 PM   #9
phase_one
The fuel pump was bad cranked right off. Thanks for the help.
11 Surbaban
70 C 10
still in progress
