Old 12-19-2006, 01:17 PM   #1
whatnow123
whatnow123's Avatar
Wrong Bed Problem??
Hi Everyone,
I have question about my recent purchase of a 67 truck. I didn't know much about these trucks until recently, but after I bought mine I noticed it came with a 66 and earlier short bed. I don't like how it's attached as they have welded brackets to the truck frame to line up the mounting locations and it's a little crooked. The bed is in really good shape but I would rather have a the correct step side bed for the truck.
I know the value of a decent bed for the 67-72 years are pretty high, but its it the same for the earlier years?
Does anyone know if I can just replace the fenders with the correct ones and fix the mounting or should I just try to find the correct bed?
Thanks in advance for the advise!
whatnow123 is offline   Reply With Quote
Old 12-19-2006, 01:30 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Wrong Bed Problem??
You're in arizona.... you should be able to get an entire 67-72 truck bed for a few hundred bucks... The funny thing is they are usally pretty cheap whole, and considerably more expensive when taken apart and sold in pieces.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-19-2006, 01:37 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The holes dont line up on the fenders and the steps are different, but it can be done.
sneakysnake is offline   Reply With Quote
Old 12-19-2006, 01:40 PM   #4
67ChevyRedneck
Are the original brackets still on the frame for the original bed? Or did they cut those off?? There should be 4 at the front, behind the cab (2 on each side) The back half of the bed sits on the frame.
Jesse James
Project "On a Dime"
Old 12-19-2006, 01:48 PM   #5
whatnow123
whatnow123's Avatar
No factory brackets what so ever. Just 4 heavy gage steal straps welded to the frame and bent at the top to connect the bed to the frame.
Old 12-19-2006, 01:53 PM   #6
67ChevyRedneck
That sucks man, this is what factory brackets look like....
Jesse James
Project "On a Dime"
Old 12-19-2006, 01:59 PM   #7
whatnow123
whatnow123's Avatar
Whew.. I have the brackets on the frame. I thought maybe you meant brackets on the bed.
Old 12-19-2006, 02:03 PM   #8
67ChevyRedneck
That's good. The bed shouldn't have any brackets on it, but it does have cross sills that go across the bed, under the wood floor, and these cross sills sit on the brackets at the front, and they sit on the frame at the back (with square rubber pads underneath them.)
Jesse James
Project "On a Dime"
Old 12-19-2006, 05:19 PM   #9
The dimensions of the stepbeds are pretty much the same from around 47 up to 87. Just the mounting of the steps and fendrs is the biggest issue. If you have a good one, you can easily adapt it to work. I converted an 84 bed for my 70.
Here is what I did to the latemodel bed.
http://myweb.cableone.net/wpalfrey/84bed/84bed_01.htm
I don't have the exact specifics on what little bit is different on the older beds.
Old 12-19-2006, 05:51 PM   #10
72armyswbtruck
72armyswbtruck's Avatar
Hey, that's not a bad little build thread
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-19-2006, 06:40 PM   #11
Thank you.
