Old 12-19-2006, 07:01 PM   #1
chevyc1068
chevyc1068's Avatar
How do I make it sound....
How would I make my pickup with a 307 in it sound loud, but with a deeper mellower sound, not a really high pitched sound? I'm putting headers, true dual exhaust. So info on what size of headers, length and size of mufflers(glass packs), tips, and size of pipes.
1968 C-10 longbed, 307 V8, 4spd- currently under construction
chevyc1068 is offline   Reply With Quote
Old 12-19-2006, 07:05 PM   #2
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: How do I make it sound....
It will sound sweet with open headers!!
AesC10s is offline   Reply With Quote
Old 12-19-2006, 07:12 PM   #3
bryanw1968
bryanw1968's Avatar
I would go with 1 5/8" headers with either a 2 1/2" or 3" collector.
Glass packs are going to be deep at idle and really loud when you nail it. However if you get a pair that are long enough it won't be near as loud and will be much more mellow. A cheap pair of turbo mufflers wouldn't sound bad and would be much quieter and mellow also. Most chambered mufflers are going to be pretty loud if that's the tone you're going for. Otherwise dynomax makes several different straight through design mufflers that would be mellow and sorta loud to very loud.
Also, I would go with 2 1/2" pipes if you don't plan on doing anything else with the motor. If you have plans for more HP later on I'd go with a 3" collector and 2 1/2" pipes. The 1 5/8" primary headers should still be fine.
IMHO
Good luck,
B
bryanw1968 is offline   Reply With Quote
Old 12-19-2006, 07:24 PM   #4
chevyc1068
chevyc1068's Avatar
You'd really go with 2 1/2 pipes on a true dual system for a 307? I thought that might be to easy of exhaust flow and you'd lose some low end torque. Would there be much difference between 2 1/2 and 2 1/4? How long of glass packs can you go before you lose a lot of sound, 11", 18", 24"???
Old 12-19-2006, 07:27 PM   #5
AesC10s
Chevy truck addict
AesC10s's Avatar
Run 2 1/2 pipe but put 2 1/4 tips on the end of the exuast to keep your low end tourqe
Old 12-19-2006, 07:29 PM   #6
chevyc1068
chevyc1068's Avatar
How do you put 2 1/4 tips on a 2 1/2 pipe?
Does it matter how close you put the mufflers to the headers what kind of sound it makes?
Old 12-19-2006, 07:50 PM   #7
AesC10s
Chevy truck addict
AesC10s's Avatar
use a tip that fits 2 1/2 pipe and has a 2 1/4 outlet. You should put the mufflers under the bed cuz if they are under the cab it will be loud inside the cab.
Old 12-19-2006, 07:57 PM   #8
pkj
2 1/2 pipes bent at local exhaust shops will be about the same as 2 1/4 pipe. they dont use mandrel bends. exhaust shop can flare or neck your tailpipes and tips so they fit. muffler location, the longer your tailpipes the more rumbel or rapping with glass packs. for what you want keep mufflers as far forward as you can, but make sure you can still service stuff like trans if you have to. those glass packs will get very load in ashort period of time. i would consider the longer ones, after some time its not load enough to piss off the comunity, then its ice water or torch time. that will get them riled.
pkj is offline   Reply With Quote
Old 12-19-2006, 08:01 PM   #9
Texasdeere
Texasdeere's Avatar
Generally speaking, the bigger the pipe and the shorter the exhaust system is the deeper it will sound. (with a drone usually) Everything will affect the sound meaning, muffler position (front to back) and how many bends are in the pipe.
For the results you want, I would say headers with 2.5" to 2.25" pipe straight back to flows or turbo mufflers and dumps at the axle. To tone it down a bit you could later add pipes to dump over the axle instead of in front of it.
Just my 2 cents.
Texasdeere is offline   Reply With Quote
Old 12-19-2006, 08:24 PM   #10
AesC10s
Chevy truck addict
AesC10s's Avatar
Just my 2 cents.
Flows lose the nice deep sound at about 2000 rpms.....atleast the 2 40 series on my 99 dodge durango do.
Old 12-19-2006, 09:50 PM   #11
kelsfine69
18 Till I Die
kelsfine69's Avatar
M2C
Flowmasters always sound good
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 12-20-2006, 01:22 AM   #12
brak
brak's Avatar
Originally Posted by AesC10s View Post
... You should put the mufflers under the bed cuz if they are under the cab it will be loud inside the cab.
I can't stress that enough.
the Previous Owner installed true duals exiting in front of the rear wheels, so the two flowmasters were directly under the seats. HOLY CRAP!!! when my friend would ride with me, we would be screaming at each other, and only 2 feet apart.
Not to mention the heat that would radiate up from the mufflers.
It probably wouldn't have been that bad, except when i removed the exhaust, i found that both mufflers had blown out / rusted through directly on top forcing all the sound and heat at the cab floor
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 12-20-2006, 02:09 AM   #13
Moneypit
I used the 2.25" kit from LMC. I got the the glasspacks(which are 18") with the stock exit. In front of that I have 1 5/8" Heddman long tube headers and ended it with echo chamber tips that measure 18" long and 3" in diameter. I picked up some power(registered by the butt-o-meter)and am able to "peel out" on dirt while in second gear which I wasn't able to do before. It has a nice low grumble that I like and is louder and meaner sounding than my friends Harley Davidson 1200S with the stock exhaust.
1968 Chevy C10
1967 Mustang
1976 Honda XL350
2006 Victory Vegas 8-Ball
2012 Ram 1500 4x4
Moneypit is offline   Reply With Quote
Old 12-20-2006, 11:58 AM   #14
smitty62
smitty62's Avatar
WHATEVER You do, don't use Flowmasters-------I will never understand what people see (hear?) in there tinny, crappy sound..they aren't deep sounding--just loud
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 12-20-2006, 12:09 PM   #15
gkolmatycki
Love that '69
In my opinion, 1 5/8" headers with either 2 1/4" or 2 1/4"" piping. If you are going to use a cat, install a magnaflow high flow cat. Magnaflow makes straight through mufflers that give a deep, mellow tone that is great, but not as raspy/high pitched as flowmaster. A pair of turbo mufflers would sound similar to stock. Chambered mufflers, such as flomaster, are going to be louder. I love the new flowmaster super 40 or original 40 on a V8 though. Dynomax makes straight through mufflers & a super-turbo muffler that would be mellow and sort of loud (super-turbo) to very loud (ultraflo - SS or Aluminized).
Personally, I like my true dual magnaflows with 3.5" tips. They are deep, mellow, & throaty. Loud enough to turn heads when you step on the gas pedal, but not crazy loud that they annoy you.
I AM CANADIAN & PROUD OF IT!!!
1969 Chevy C10, SBC V8, TH-350 Transmission, Metallic Blue, B&M Megashifter, GT Grant Steering Wheel, 2.25" True Dual Magnaflow Exhaust System w/ SS Magnaflow Embossed Tips, 700W Rockford Fosgate Stereo System, Lowered 1" Front & Stock Rear, 4.56 Rear with Positraction, 15" Chrome Rims w/ Chevy Center Caps & Michelin Tires, 4.5" K&N Air Filter, Edelbrock 'Elite' Engine Accessories, Chrome Powdercoated Engine Parts
2001 Cavalier Z24, 2.4L DOHC, Silver, Spoiler, AEM Intake, 2.25" Magnaflow Exhaust System, Clear Euro Tails, Tinted Windows, 400W Clarion Stereo System
gkolmatycki is offline   Reply With Quote
Old 12-20-2006, 12:10 PM   #16
gkolmatycki
Love that '69
Sorry, my bad, 2 1/4" or 2 1/2" piping.
Old 12-20-2006, 02:26 PM   #17
68Stepbed
68Stepbed's Avatar
If you want a deeper tone, stick with manifolds. Headers will give you the higher pitched sound. The larger 2 1/2" pipes will also carry a deeper tone than 2 1/4", but it won't make a big difference. I personally don't like glasspacks because they are high pitched, especially after about 6 months or so of use. If you're serious about glasspacks though, I recommend a set of Smitthy's. They come in two lenghts. Get the longer ones.
An H-pipe or balance tube, not an X-pipe, will also help with a deeper, more mellow tone.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-20-2006, 02:43 PM   #18
72 cheyenne pdx
72 cheyenne pdx's Avatar
IMO - go with 2.5 pipe and use Borla mufflers. I think Borlas are the best sounding muffler on the market.
72 cheyenne pdx is offline   Reply With Quote
Old 12-20-2006, 02:54 PM   #19
ClassicRedneck05
ClassicRedneck05's Avatar
im using the Race Magnum Bullet mufflers from Dynomax i got them from JEGS for a decent price http://www.jegs.com/webapp/wcs/store...9716_-1_128827
and i have cheapy lil headers and mine sound AWESOME but a good cam will help as well im actually bout to order me some Hooker Compititions i think i have got good feed back from others who have them
ClassicRedneck05 is offline   Reply With Quote
Old 12-20-2006, 03:14 PM   #20
chevyc1068
chevyc1068's Avatar
So what happens if you get cheap glass packs? Like the ones Summit offers? Do you just get a loud sound, a deep sound, or is it to muffled?
Old 12-20-2006, 03:20 PM   #21
ClassicRedneck05
well my cousin ownes a muffler shop here in Cleveland Tx and i went to him on it he told me the inhouse brand they had would saoud the same as what i got ALMOST just not as loud keep in mind with these types there is a thin thin thin layer of the glass packing hense being a race muffler and sound MMMMMMMEEEEANNNNNNN as hell whenh u open it up but they inhouse brand doesnt lat as long either
Old 01-10-2007, 12:53 PM   #22
Mrboson1
Chevy 400
Mrboson1's Avatar
My uncle has a the x-pipe on his 68 chevy c-10. We felt it gave the truck a deeper tone. Sound really good. When we back the truck out of the garage it shakes all the dishes in the kitchens.
68 Chevy C-10 pickup
Mrboson1 is offline   Reply With Quote
Old 02-10-2007, 08:01 PM   #23
bigtruck81
i have 1 5/8 headers on my 77 with 2 1/4 pipe, and 40 series flows. there's nothing high pitched about it. just a nice low rumble at idle or cruise, and when you get in it, they really sound like a flowmaster.
bigtruck81 is offline   Reply With Quote
Old 02-10-2007, 09:48 PM   #24
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
http://www.jegs.com/images/photos/38749100.jpg
I have the FlowTech afterburner headers, 2.5" pipe with glasspacks (I'm pretty sure they're 18"), 4" x 24" rolled slash cut tips that run all the way out the back & exit in the corner
I ran the dog pee out of my truck the first few months, to try and make my glasspacks louder (it didn't do much) but in my opinion it's not loud enough
The 4" tips give it a really nice deep sound until you hammer it, then it's pretty loud (kinda raspy / coarse)
Oh yeah, & it's a true dual setup
If you don't care about performance (and have the extra money) go with 3" & dump it under the bed for deep sound
Also if you aren't glued to a dual exhaust, then the sound of a single 3" muffler dumping under the bed sounds good to me
I've heard some single 3" flows dumping under the bed that sounded good (dunno what series), & my 90 has a single 3" that runs into a 3" x 14" glasspack that I took some 4" or 5" exhaust pipe and built a 45 degree tip that I welded to the shell of the muffler (it sounds really good, deep and really aggressive but not poppy or raspy like most glasspacks) it dumps right in front of the axle
It's all about your particular taste, but I hope this helps
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-10-2007, 10:08 PM   #25
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
My 1967 with a 350 had used hooker headers with the 3" collector (I think, didn't actually measure). Its whatever the most common size is I'm sure.
ANyway, I ran a foot of straigh pipe (on both sides) 18" cherry bombs, and used 45 degree angles plus another foto of straight pipe. THey dump off between the cab and bed, but are still hidden. No H pipe or anything.
My dad says they sound like crap, but I love them! I've gotten used to having to scream to talk to my passenger.
Even still they aren't "low" enough for me, so I might have the exhaust go to rear exits under the bumper and install cable-operated cutouts. So, if I feel like it, I can run open headers with the pull of 2 knobs.
*Sighs* I remember the first night I had that V8 in my truck, which was a Friday. I had the foot of pipe and the cherries and that was it. (The extra pipe afterwards was enough to mellow it a lot.) I pulled up next to some uptight, upscale couple in a BMW SUV. Popped that bad boy in neutral and stood on the pad. Those richies jumped out of their skins.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
