Primer over POR15 WRINKLED!
Jamie_72 sent me a note re. putting primer over some POR15 and it got all wrinkled. Can anyone with experience on this help him out with a follow-on to this Thread? When I have used POR15, it was usually in a spot that I didn't care if the cover paint wrinkled as long as it sealed the rust! Thanks---Huck
From the POR-15 web store:
PRIMING OVER POR-15: Use POR-15 Tie-Coat Primer after POR-15 is dry, following directions on can. Tie-Coat Primer may be sprayed or brushed in multiple coats if desired. Sands to a perfect finish. This information should have been included with the product...
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
![]() Join Date: Apr 2000
i used the tie coat primer over the por-15,just like it said,it was completly dry shot primer over it,and it just crumbled up....the places with no por-15 on it look great
![]() can i just sand it off and ruff up the por-15 and shoot it again?????
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
I don't think you need to use another primer over the tie-coat..
If I were you, I would either call or send a note to the POR-15 people... http://porstore.com/contact.htm
well i e-mailed the por-15 people,we`ll see what they say,
i used another primer because the tie coat is light,and the red oxide primer is dark,didn1t know if it would change the color of the paint... thanks for the replies
