Old 12-20-2006, 11:58 AM   #1
pgf545
pgf545's Avatar
Question AC Units
Has anyone put AC on their 47-54? I have looked at Vintage and Coyote Air. How do they fit, work etc? What do you guys think.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 12-20-2006, 12:33 PM   #2
Gene Sharp
Re: AC Units
I got the Vintage Air setup from a dealer in Nevada (Auto Motif)
Also got the " Front Runner" Front Drive setup,,,,,,,,, billet brackets for everything and Aluminum water pump it is really great
have not got the inside stuff installed yet yet........ but it appears to fit well
Gene
Gene Sharp is offline   Reply With Quote
Old 12-21-2006, 03:35 AM   #3
Daniel U
Daniel U's Avatar
Re: AC Units
If you're interested in some other close up pics, I can email you some. Otherwise there's some in my build thread...
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 12-21-2006, 10:30 AM   #4
solidaxel
solidaxel's Avatar
Re: AC Units
I used a Vintage Air Gen ll, works great here in the desert once you get the cab cooled down from 135-140*. The 5 windows are like cooling a green house, takes about 5 miles, the fan blows a good amount of air on high, and after it cools down I run it on med. If you are keeping your cowl vent pre fit the Evap and ducts to the defroster vent on the passenger side. I did not do that and after all was mounted and plumed I placed the ducts and had to move the Evap. down 1 1/2" so I could use the cowl vent and defroster (not at the same time!!!). Which ever one you use be sure and pore a quart of water in the evap. and make sure your condensate plumbing is tilted to the drain and you get a quart out of the drain ! Leaks are hard to correct after it is in place and your carpet is wet!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-23-2006, 11:06 AM   #5
pgf545
pgf545's Avatar
Re: AC Units
Did you guys use the under dash vents or did you fab up something for in dash? I don't know if there is even enough room for hoses etc. Anyway thanks for the responses and I am a ways from installing but just wanted to do the research.
Thanks Bernie
Old 12-23-2006, 11:20 AM   #6
CAL 58 GMC
CAL 58 GMC's Avatar
Re: AC Units
Also look into Old Air Products and Hot Rod Air.
CAL 58 GMC is offline   Reply With Quote
Old 12-23-2006, 12:04 PM   #7
solidaxel
solidaxel's Avatar
Re: AC Units
I just hung the three vents under the dash, and two defrost vents.
I think I will install three round vents in the 53 that I am building. I saw a Ford the other day at the Chassie shop that had them in the dash and I liked the way they looked!!
LS 3 4L70E
