Old 12-20-2006, 12:53 PM   #1
cochino12
It followed me home?
cochino12's Avatar
400 hp and air over leaf?
Does anybody think this will be a problem? I plan on running air over leaf to keep things simple, but I also want to have some decent power as well. I will be using a mildly built 454, 700r and it will be in a 76 2wd Blazer. Any input or other ideas?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-20-2006, 01:40 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 400 hp and air over leaf?
I imagine that unless you are going to drag race daily, then you wouldn't have any issues with your axles wrapping around themselves.
piecesparts is offline   Reply With Quote
Old 12-20-2006, 09:01 PM   #3
magnethead
7000 #'s of american IRON
magnethead's Avatar
you arent saying if that 700 is built or not, but with 400 HP i'm willing to bet you'll have a hole in your floorboard before you get axle wrap.
magnethead is offline   Reply With Quote
Old 12-21-2006, 01:01 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
I can't say about a 400 hp motor, but my Ramjet 350 is rated at 350 hp and 400 tq. With an air over leaf system, 700r4 and 3.08 gears it works just fine. I don't really beat on it, but when I do gas it hard it goes sideways and I don't have any wheel hop.
How well it works depends on your rear gears and tire height too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-21-2006, 03:09 PM   #5
piecesparts
Buuid the 700 if you haven't already. It will stand up to 400 HP if you have the right parts.
Old 12-21-2006, 06:22 PM   #6
cochino12
cochino12's Avatar
yep, the 700r will be built to handle the motor I'm not to worried about that. Thanks for the help
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-21-2006, 06:34 PM   #7
craig@ridetech.com
Formerly LSC71
The air over leaf kit will handle the power. axle wrap is more about how good of traction you are getting, as with any leaf spring set up you are going to have a certain amount of axle wrap. You could always switch over to a 4-link if you don't like the way it turns out.
craig@ridetech.com is offline   Reply With Quote
