Old 12-20-2006, 03:01 PM   #1
rcatalano
rcatalano's Avatar
Lower Control Arm Bushings
I've been lurking around the site for a couple of months and I'm getting started on the restoration of my 71 c10 shortbed. I'm starting to reassemble the front suspension and have a few questions on the installation of the lower control arms. Ive done some searching and can't seem to find the answers. According to my chassis manual, the lower busings need to be torqued to 280 ft/lbs?? Am I reading this right? The bushing nut is 1 5/8" and I have a 3/4" socket set with that size, but my torque wrench is only 1/2" drive and I don't have a socket that big. Also, my torque wrench only goes up to 200 ft/lbs. These are new bushings. Anyone have any ideas as to how I can get this back together?
Thanks!
Rick
rcatalano is offline   Reply With Quote
Old 12-21-2006, 04:57 PM   #2
rcatalano
rcatalano's Avatar
Re: Lower Control Arm Bushings
Anyone??
Old 12-21-2006, 07:16 PM   #3
XXL
Seņor Member
XXL's Avatar
Are you talking about the u-bolts that hold the cross-shaft in place? Or???
XXL is offline   Reply With Quote
Old 12-21-2006, 07:19 PM   #4
Shane
Shane's Avatar
I think he is referring to the nut on the cross shafts.
Shane is offline   Reply With Quote
Old 12-21-2006, 07:31 PM   #5
crazy longhorn
Fabricate till you "puke"
I have never torked them, just pulled them up goood & tight with a breaker bar(thats about a ft longer than your tork wrench). I am in the same boat.....the tork wrench dont read that high! I have done several trucks that way, & not a problem.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-21-2006, 07:45 PM   #6
XXL
Seņor Member
XXL's Avatar
Stop talkin' dirty to me like that.
I believe 280ft/lb can be precisely achieved by sliding a large jack handle over a Craftsman 1/2" breaker bar, and at the point that the handle on the breaker bar shatters, you're at 280.
Old 12-21-2006, 07:58 PM   #7
rcatalano
rcatalano's Avatar
Thanks for the responses!!
Rick
Old 12-22-2006, 08:48 PM   #8
deoncollins69
The best part about that process is?
1. You can now pick up chicks by telling them you are wounded war veteran.
2. you will be allowed to go around all the metal detectors at the airport.
3. Since you shattered your craftsman you get a free one to do the other three nuts.
deoncollins69 is offline   Reply With Quote
Old 12-22-2006, 09:30 PM   #9
crazy longhorn
Nah, you just tork it to 1/4 turn past bend.....then back it up approx 1/2 turn(DONT BREAK THE WRENCH!) Ok, joke over..... unless you are one bad azz .....read (big MOFO), i doubt you can pull the a arm bushings up tight enough to break anything When you do the ball joints, tie rods, u bolts , ect.....i do reccomend the proper usage of the tork wrench however. you boys can call me "hills", but after all the yrs playin, I do tork up internals on the eng/trans/rear diff.....the rest is on "feel"......if it feels good DO IT! crazyL
Old 12-22-2006, 10:55 PM   #10
XXL
Seņor Member
XXL's Avatar
...do the other three nuts.
4 nuts?
Old 12-23-2006, 03:49 PM   #11
crazy longhorn
4 nuts?
Actually, the front end of that truck must be pretty well hung.......it has 8 nuts! L
Old 12-23-2006, 04:06 PM   #12
XXL
Seņor Member
XXL's Avatar
No kidding... especially since some of us only have one.
Old 12-23-2006, 08:01 PM   #13
deoncollins69
I have two but they have been surgically disabled so does that count?
