Old 12-20-2006, 04:27 PM   #1
shopking72
shopking72's Avatar
Power Steering problem
I just finished my new motor a couple weeks ago. And I have power steering on my truck. But it is not working very well, and every once in a while fluid will shoot out of the cap of the pump! And I did NOT overfill it, and the belt is not loose or worn, I double checked. Just seeing if you guys think its the pump or maybe the gearbox is even bad too, thanks
Wes
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline   Reply With Quote
Old 12-20-2006, 06:24 PM   #2
68CHEBY
Re: Power Steering problem
Wes
Sometimes on a new pump or an old one that has been drained and refilled, they can develop air pockets in the pump and or lines, that could cause some of that problem. I would run the steering through its motions for a while and make sure that this is not the case before I looked any farther.
68CHEBY is offline   Reply With Quote
Old 12-21-2006, 05:57 PM   #3
Americanrider
I had to "Burp" my new PS system after installing. It's best to do it at a idle while turning the wheel back & forth from stop to stop.
Americanrider is offline   Reply With Quote
Old 12-22-2006, 12:32 PM   #4
shopking72
shopking72's Avatar
I did that mulitple times, I jacked up the front of the truck and turn the wheel back and forth a few times. But it still isnt working, but it was before I put my new motor in, thats what is weird.
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
