turbo enthusiast
coil spring question
would front coil springs for a 2wd 1 ton truck fit in the front of a 2wd 3/4 ton truck? They look like they will fit, so I'm guessing the ride will be a just a little stiffer.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
its all about the +6 inches
Re: coil spring question
yep, they'll swap fine
Living In The Past
yep , they'll fit. I have done it. I have some brand new 1 ton springs if your looking for some.
turbo enthusiast
I have some new ones also, but does the 1 ton springs lift the front end up higher than stock? Does anyone make 1 ton rear coil springs for these trucks?
Living In The Past
I dont know about the back springs but on the front you need to cross reference the part numbers with 3/4 ton springs where your buying them from. When I was looking for one ton springs I found that a lot of places had the same part # for both 3/4 and 1 ton. If you find the true one tons yes it will sit higher because they wont compress as much with the weight on them.
turbo enthusiast
thanx Olden Days
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I was wondering the same thing.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
I have one ton springs in the front of my 1/2 ton with 3 inch drop springs in the rear. My pic is what you will get.
Fuzzy |
wow... 4 year old thread... almost to the day!
There is no such thing as one ton coils. All C/30 trucks had leafs in the back |
#10 | |
Lmao!
