12-20-2006, 08:29 PM | #1 |
lowering blocks: good or bad
can 2" lowering blocks cause problems? or is there any downfalls using lowering blocks?
12-20-2006, 09:42 PM | #2 |
Fabricate till you "puke"
Re: lowering blocks: good or bad
Actually, I think a 2 drop block in the rear of a coil spring truck is a better deal than a spring drop, as you still have the load capacity as was stock. The only downside on the block drop , is that 2-2 1/4" is about max with a 15" wheel combo to maintain proper "scrub lines" . You dont want any suspension pcs hangin below the wheel , in case of a blowout on a tire(YIKES!) if you are conservative on the block drop, i see no downfalls L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
