Old 12-20-2006, 09:45 PM   #1
ROOFTOP SPECIAL
Whats a good price for a 68 4x4 step side
Hey guys,
It been a while since I last posted. Here is my question.
Whats a decent price for a 68 4x4 step side w/ a 350? The body looks really straight and very little rust, but you know how that goes. Its got a cheap paint job, AC, power disc brakes, power steering, manual tranny and the interior is decent. I would also like to know how to test the 4 wheel drive other than getting it stuck and then testing it. I'm use to my new truck where its push button, I know kinda spoiled. So I'm guessing a lock the hubs and with the truck in neutral move the lever? How do a confirm it's working. I know these may sound like the "stupid" questions but I'd rather know and not guess.
I can get it for $4000, that seems like a good price for an original 4x4.
Thanks for the help,
Casey
ROOFTOP SPECIAL is offline   Reply With Quote
Old 12-20-2006, 09:49 PM   #2
1969k10stepside
Re: Whats a good price for a 68 4x4 step side
If its a 68 it wont have disc brakes unless its front axle has been changed.
1969k10stepside is offline   Reply With Quote
Old 12-20-2006, 10:17 PM   #3
avejoe
Custer had a plan too.
avejoe's Avatar
$5
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 12-20-2006, 10:18 PM   #4
ROOFTOP SPECIAL
Sorry I said 68 but it's actually a 67. I guess it would be nice to find out what year front axle is on it, for parts and stuff.
Old 12-20-2006, 10:29 PM   #5
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Whats a good price for a 68 4x4 step side
look closely at the p-s set up too. 67-68 never had intregal power steering on 4x4s and had a flat frame where the box bolts on. i've heard that p-s was available on 67-8 4x4s but it was the ram assist type, i personally have never seen one. is it possible the body has been put on a newer frame? easy to tell if the frame has been changed,67-8 had cast front spring mounts and 69-72 were stamped steel(the ones under the rad support). it's much more difficult to find suspension components for the 67-8 style. if everything is done right then 4K is'nt a bad price. hope this helps.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 12-21-2006, 06:11 PM   #6
Americanrider
Short step or long step? Big window 67 or a small window cab? Pics would help. Where is reverse on the tranny shifter, drivers side & down or pass side & down?
Americanrider is offline   Reply With Quote
Old 12-22-2006, 06:45 PM   #7
ROOFTOP SPECIAL
I had a friend look at the truck with me. We determined that the Cab is not off of a 67. It's got the plugs for the shoulder seat belts and a seem that runs across the back top of the roof. I thought 67's did not have either of these things? Reverse is Drivers side and down. It seems to be a clean truck but I don't like the fact that the cab has been swaped.
Old 12-22-2006, 06:49 PM   #8
1969k10stepside
Look at the VIN on the cab.It will tell you what year unless its VIN has been swapped in which case I would wipe my fingerprints off the truck and never look at it again
Old 12-22-2006, 07:58 PM   #9
zeeklu
My 67 has the plugs , the seam and reverse in the same spot.. Chris
zeeklu is offline   Reply With Quote
Old 12-22-2006, 08:19 PM   #10
CPNEJR
CPNEJR's Avatar
the tranny is definately 67 and all these cabs had the plugs and the seam
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 12-22-2006, 08:26 PM   #11
msgross
msgross's Avatar
send pics dude, I bet that it's on a newer frame...Where is 2HI on the Transfer case? If it's all the way forward then it might be original, if not then its newer. If it was only and axle swap and the truck is otherwise near original then 4K isn't bad. I bought my 68 SWB K-10 fleet for 1600 but its not running. I have 4K in it now and it's in parts in the garage. I will have discs and PS too but only after I put my 76 axle under it.
msgross is offline   Reply With Quote
Old 12-22-2006, 08:44 PM   #12
1969k10stepside
Post pics here or you can email them to me and I will post them.Take a pic of the transfer case,the truck in general,the spring hangers(mounts).Measure the length of the rear springs.If you have all that stuff we can determine the year.
Old 12-22-2006, 11:09 PM   #13
ROOFTOP SPECIAL
Thanks for all the replies. I guess my buddy was wrong about the plugs and seem, That's good! The VIN tag matched the registration and that said 67. I'm not able to get the pics for a while. The truck is at a park and sell lot, they are closed through Christmas and I'm out of town through the 3rd of January. I couldn't tell where the low was but I did shift it into 4 wheel drive.
Old 12-23-2006, 01:39 PM   #14
Americanrider
The tranny is a Sm 420, last year used was in the 67's. Most likely has the Rockwell T221 transfer case.
Old 12-23-2006, 04:59 PM   #15
1969k10stepside
Posting pics for Rooftop.The pics so far suggest it is a 68 because it has the sidemarker lights but I cant tell,it looks to not have the sidemarker lights on the bed.
Name:  68 Chevy.jpg
Name:  68 chevy-2.jpg
Old 12-23-2006, 07:07 PM   #16
msgross
msgross's Avatar
not bad looking...If it ran great and could pass a mechanical inspection then $4K isn't to far from a decent price. Looks like an aftermarket A/C was added but the wheel and E-brake handle are 67/68. Try to show him $3200 and see where it goes. What engine is in it? any tow hooks?
Old 12-24-2006, 01:12 AM   #17
FarmTruk
In Memoriam...
FarmTruk's Avatar
That's a nice looking 4x4.
What's that red wire in front of the clutch ped. go to? And is that a spinner knob on the steering wheel? Old School!
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 12-24-2006, 01:19 AM   #18
1969k10stepside
Just notcied it has a big back window and maybe a sliding rear window.
Old 12-24-2006, 10:52 AM   #19
msgross
msgross's Avatar
i think it's the shifter knob...
Old 01-04-2007, 05:21 PM   #20
ROOFTOP SPECIAL
I just got back from vacation. The window is a big back window with a slider. The title says it's suppose to be a 67. I beleive it have a 350, that's what they say it has. The truck is at a "Park and Sell" type lot. It had $5500 but they guy that ran the lot said 4G's is what he would take. They disconnected the AC when they replaced the RAD. He said it would be hooked up and working if I bought it. I'm thinking og offering $3500 and see what happens. I found it hard to find other 67-68 4X4 to compare it to. And if I did they had been restored. I appreciate everyones help. I'll try to get more pics tonight. Thanks 1969k10stepside for posting the last pics, I might send you more.
Old 01-04-2007, 05:29 PM   #21
jerry moss
Born Psycho
jerry moss's Avatar
the pic looks nice until i looked at the inside ---it looks like a miracle paint job. check it close for hidden rust covered by bondo.
jerry moss
Old 01-04-2007, 07:39 PM   #22
72armyswbtruck
72armyswbtruck's Avatar
So did you get this truck or what?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-04-2007, 08:40 PM   #23
FarmTruk
In Memoriam...
FarmTruk's Avatar
One more thing...if the motor is a 350, it is not original to the truck. That can be a good/bad kinda thing.
FarmTruk Pics Here
Old 01-04-2007, 09:02 PM   #24
68 Stepside
huh?
68 Stepside's Avatar
It may have had the front fenders replaced, since they have side markers. I notice the rear fenders don't have them. I would bring a weak refrigerator magnet with me, and take a very close look at it.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 01-04-2007, 11:00 PM   #25
wolfthing2000
I guess we never determined the transfercase. The old 221 ran through a gear train even in direct high so they are a bit noisy, but strong. If it is a 205 with the lever having low in the forward position that is also a good thing. make sure the 4 speed you have does not POP out of second. The 420 ( when worn) will start to do it.
I would look at the cab corners at the rear of the cab and the kick panel area on both sides. The rockers are a no- berainer. Poke around a little on the body supports under there too. I checked one out and as soon as I pushed on the body support a hole opened and sand and rust poured out!!!!.
I think you are on to a good truck if it has a decent body, good glass and is in good servicable condition( driveable).
I payed 1800 for a 68 K-20 2 years ago with thrash driveline, wore out engine, and lotsa body work ........still workin on her!!!!
wolfthing2000 is offline   Reply With Quote
