Old 12-21-2006, 12:31 AM   #1
CHAPS7931
CHAPS7931's Avatar
contitech vs Slam Specialty
my self i use the contitech 4 ply with dual port and i love the response i get when running high psi but would like to get some more info on what bags the other members are using and why?
CHAPS7931 is offline   Reply With Quote
Old 12-21-2006, 05:50 AM   #2
jimmydean
jimmydean's Avatar
Re: contitech vs Slam Specialty
I am using Slam RE7's in the front, and RE6's in the rear. I am about to order a 2 more RE7's for the rear for the added ince of lift. I like the internal stops and they don't seem to balloon either.
jimmydean is offline   Reply With Quote
Old 12-21-2006, 10:47 AM   #3
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Jimmydean, how much drop does your truck have with those bags? any drop spindles or just bags? im about to do my truck and trying to figure out which bags to use. thanks
1967 C10 swb
1970 GMC Jimmy 4x4
2005 Chevy tahoe Z71
2001 Chevy impala
bcj67chevy is offline   Reply With Quote
Old 12-21-2006, 12:13 PM   #4
jimmydean
jimmydean's Avatar
With 2.5" drop spindles and uncut Suicide Doors cups in the front and a 3" cup in the rear, it looks like this:
The rear is sitting on the stock bump stops and my frame is uncut. I will go about 3" lower once I get my new exhaust. I will notch the frame and cut the cups. I'm also getting slightly smaller tires I think.
Old 12-21-2006, 03:48 PM   #5
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Jimmydean, why would you need cups in the back, wouldn't it just bolt from the trailing arm to the frame?
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 12-21-2006, 04:06 PM   #6
1lowdiesel
1lowdiesel's Avatar
i'm using re's on diesel and i'm gonna use the same on my c-10. i love em'
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 12-21-2006, 04:57 PM   #7
jimmydean
jimmydean's Avatar
I didn't need cups, but I had them and without, the back would be lower than the front. This way it sits even and I didn't have to notch my frame.
I will pull the back cups out after I notch the frame. I will cut the front cups down to keep the stance even.
