Old 12-21-2006, 02:26 AM   #1
HotRod73
HotRod73's Avatar
How to tell the difference...
I have a nice aluminum high rise intake from a chevy but cant remember if it fits a sbc or a bbc... is there a way to tell? all it says on it is Pro/Stock
i am hoping its a sbc....
HotRod73 is offline   Reply With Quote
Old 12-21-2006, 08:37 AM   #2
HotRod73
HotRod73's Avatar
Re: How to tell the difference...
anyone???
Old 12-21-2006, 09:25 AM   #3
sick69
sick69's Avatar
if its a bb intake you'll know mainly because of its size.
bb intakes are quite a bit bigger(length and width) than the sb intakes and the are no where near interchangeable
do you have a sb in your truck or sitting in the garage? set the intake on it or next to it and see if it looks close.
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 12-21-2006, 10:42 AM   #4
ScottH
ScottH's Avatar
I believe BBC manifolds have extra bolts.
Do a search on ebay for both and compare the pics.
1963 C10 swb fleetside
1966 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 12-21-2006, 11:06 AM   #5
HotRod73
HotRod73's Avatar
this has 6 it looks huge though it looks like a sbc but then it dont
Old 12-21-2006, 11:53 AM   #6
ScottH
ScottH's Avatar
post a pic
Old 12-21-2006, 12:06 PM   #7
HotRod73
HotRod73's Avatar
how? i dont have a url
Old 12-21-2006, 12:12 PM   #8
ScottH
ScottH's Avatar
Try downloading it to photobucket
Old 12-21-2006, 12:18 PM   #9
stepside454
stepside454's Avatar
small block intakes have all the bolt holes close to inline.
Big blocks have 2 bolts on each side clearly out of line. those 2 sit dead center above & sort of between 2 ports.
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 12-21-2006, 04:11 PM   #10
OLDCHEV4X4
OLDCHEV4X4's Avatar
Look for the fitting that comes strait out the front for the short 90 deg. hoze. Small blocks don't have that.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 12-21-2006, 05:30 PM   #11
HotRod73
HotRod73's Avatar
here are the pics...
Old 12-21-2006, 05:34 PM   #12
HotRod73
HotRod73's Avatar
i only need it if its a sbc if its a bbc i cant use it (dont have a big block) so im hoping this is a sbc
Old 12-21-2006, 06:59 PM   #13
ScottH
ScottH's Avatar
You are in luck, SBC
Old 12-21-2006, 10:33 PM   #14
HotRod73
HotRod73's Avatar
yeah but it has "Look for the fitting that comes strait out the front for the short 90 deg. hoze. Small blocks don't have that"
doesnt it??? sure its a sbc????? if so YEPEEEEE
Old 12-21-2006, 11:44 PM   #15
HotRod73
HotRod73's Avatar
anyone ever seen an intake like this before? it doesnt have any other names or numbers on it just "pro stock" are u sure its a sbc and not a bbc???
Old 12-21-2006, 11:51 PM   #16
HotRod73
HotRod73's Avatar
i also just noticed the back two port holes on the bottom of the intake look like they have been filled in... here is pic.... why is that??? is it useable or what???? [IMG][/IMG]
Old 12-22-2006, 11:34 AM   #17
OLDCHEV4X4
OLDCHEV4X4's Avatar
SBC...It dosen't have the fitting coming "strait" out the front.
Coolant passages are blocked off in the back. Its a single plane...I wouldn't use it unless you have a small block thats gonna turn 6000rpm or more. Your gonna loose a lot of low end. What are the motor specks that you are putting it on?
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 12-22-2006, 11:58 AM   #18
HotRod73
HotRod73's Avatar
LOL stock 350... with exhaust... lol hahaha.... guess this wont work for me, i will try and trade it for a different sbc intake i guess
Old 12-22-2006, 06:06 PM   #19
HotRod73
HotRod73's Avatar
so it wont work on my motor?
Old 12-22-2006, 07:00 PM   #20
gflo383
Yes, it will "work" but like he said the volume of air that intake is designed to flow if for higher reving 350's or larger cubic inch strokers etc that need a large volume of air. On a single plain intake like that one, there is an extreme loss of velocity due to its larger plenum/runner size, the loss of velocity causes a loss of low end low RPM torque. your stock 350 would have no responsiveness at all, and unless you have a bottom end that can handle 6500 RPM's it wont make any useable horsepower either.
hope that helps.
Joe
1986 IROC-Z lS1/T56 Moser 9" 78mm Turbo
1968 C10 step side, 5.3 Maggnacharger TVS1900 6L80E
2009 CCSB 5.3/6L80 4x4
http://members.cardomain.com/gflo383
gflo383 is offline   Reply With Quote
Old 12-22-2006, 09:00 PM   #21
HotRod73
HotRod73's Avatar
anyone wanna trade for a different one or buy it for $40 bucks???
Old 12-23-2006, 12:30 AM   #22
84slopwaggin
84slopwaggin's Avatar
You'll have no trouble trading it off for a more usable piece.
84slopwaggin is offline   Reply With Quote
Old 12-23-2006, 12:36 AM   #23
HotRod73
HotRod73's Avatar
sorry i forgot i cant post for sale... my fault... i need to just pay and become a member
Old 12-25-2006, 10:22 PM   #24
HotRod73
HotRod73's Avatar
I Am Trading For A Stock Aluminum Intake Off A 85 Iroc Z28 Plus I Am Getting $10 With It, Is That A Good Deal?
1973 Chevrolet C20 (Under Construction)
Old 12-26-2006, 11:19 PM   #25
7387chevys
The intake you have is more expensive and better for performance@high rpms but if you dont have someting to use it on its worthless A performer eps(if running a squarebore carb) will net a quite noticable power gain over stock intakes..........Spacer plates also help some what 1 inch with preformer eps gives a mild yet noticable lope (sounds awesome)at idle even with a stock camshaft.
Shane
7387chevys is offline   Reply With Quote
