Old 08-21-2002, 03:48 PM   #1
trinic
trinic's Avatar
Where can I find the Tach to fit my Cluster?
Would like to add the RPM tach for my cluster.
Where could I find one? Don't want to add an
aftermarket Tach...prefer to keep it more
original...here's a pic of my cluster
Thx,
T.C
trinic is offline   Reply With Quote
Old 08-21-2002, 03:50 PM   #2
Michael A. K. G
LMC Truck sells them, but they are not cheap.
Michael A. K. G is offline   Reply With Quote
Old 08-21-2002, 05:24 PM   #3
THOR 50
Over worked under paid
THOR 50's Avatar
Try these for a start
It's not really worth it but...
GMC Paul's
http://www.gmcpauls.com/
Tachometer Conversion Kit $229.95
Includes 2 Piece Case, Printed Circuit, Tachometer
Lens, Tachometer Harness, and Tachometer,
everything needed to convert a gauge dash to a
tach gauge dash.
Tachometer-Vacuum Gauge Conversion $309.95
Includes Tachometer/Vacuum Lens, Tachometer,
Vacuum Gauge, Front & Rear Housing, Vacuum
Gauge Backing Plate, Tachometer Wiring Harness,
Printed Circuit
WES's
http://www.classicheartbeat.com/
67-68 Complete Dash Cluster W/ Tach $469.95
Didn't see a conversion kit at WES's site
Kenny's Trucks
http://www.kennystrucks.com/home.html
Complete Tach Conversion Kit $225.00 ea
Cheyenne Pickup parts
http://www.cheyennepickup.com/
KTH8228 Tachometer Kit $250.00
includes Guage, Harness, circuit board, metal
housing, dash lense
Roger
'69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears
THOR 50 is offline   Reply With Quote
Old 08-21-2002, 06:27 PM   #4
speeddemon
speeddemon's Avatar
check at your local junk yards or at swap meets. I bought a complete tach dash with wiring harnes for 125.00 at a swap meet.
69-C10 LWB
71- fleetside shortbed
It's a shame stupidity isn't painful
Never play leapfrog with a unicorn
speeddemon is offline   Reply With Quote
Old 08-21-2002, 07:20 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Do you want one just to have one, or do you want to actually know what RPM your engine is running.
If it is just to have one, then you'll end up overpaying for one onless you get real lucky and score on at the junk yard.
If you actually want to know what your engine is doing, get an aftermarket one. The original tachs weren't all that acurate when new, and are even worse 30+ years later. They don't even go to the engine's redline.
Old 08-21-2002, 09:38 PM   #6
too many
too many's Avatar
Smile ORIGINAL TACH ??
I've got a couple of used original tachs "in the rafters". anything from "for parts" to working tachs with complete bezels and wiring harnesses. Like "longhornmail" says , they usually arent that accurate. BUT they do look cool!
PM me if interested. ( going to be gone a couple days)
too many is offline   Reply With Quote
Old 08-22-2002, 02:41 AM   #7
Hooter
My other Love
Hooter's Avatar
i used a stewart warner tach. it fit almost perfectly. Completely covers the hole. The only part that sticks out is the chrome ring on the front.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 08-22-2002, 08:08 AM   #8
Huck
Huck's Avatar
Your dash cluster and a tach dash cluster are different in several respects--plastic lense, plastic printed circuit board, mounting housing. The bezel is identical. You could probably pick up a complete tach dash off e-bay for around $200. You could probably find one from a member for less. They are far more common on larger trucks, sometimes with air pressure or vacuum guages too. They came as both 6cyl and 8cyl but in reality, all you need to do is turn a screw in the back to adjust for either. The wiring harness for the Tach is nothing more then two wires with slide connectors on them.
They do look cool and give some indication of rpm but as Andy says, they are far from accurate. Good luck~~~~`Huck
Huck is offline   Reply With Quote
Old 08-22-2002, 11:48 AM   #9
gabet40
the sun-tach II fits perfect. all you have to do is take apart your cluster and cut a hole in the plastic for it. i ended up sawin it in half and cuttin straight lines cuz the plastic is so fragile, cracks really easy. but the tach fits so snug in the hole you dont have to attach it to anything
Current owner of 2016 2500 Silverado Midnight Edition.
Former owner of:
69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4
72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust
gabet40 is offline   Reply With Quote
Old 08-23-2002, 02:21 AM   #10
Fast68Chevy
Fast68Chevy's Avatar
dont forget the commonplace 75-81 camaro tachs, they read little higher and loo 90% same as ours and are same size and all and are for HEI
not sure why ppl overlook these.,, is a great tach to get and use,
i got my ast 75-81 tacxh dash from a 77 or so LT-type(or something like that model) silver camaro, if i was building a 67-72 dash then id be using that tach for sure, a few members here have one in theirs,.
good luck
Fast68Chevy is offline   Reply With Quote
Old 08-23-2002, 01:45 PM   #11
dmec
dmec's Avatar
i prefer the camaro 7000 rpm tach
dmec is offline   Reply With Quote
Old 08-23-2002, 05:04 PM   #12
Longhorn Man
i over look it becouse it is still inacurate, and it does not look stock to me.
