Old 12-21-2006, 11:53 AM   #1
slytat
slytat's Avatar
remote start
My question is, I have a 76 Gmc 1/2 ton 2wd shortbox, it has rebuilt 350 with a 400r tranny. can I use a remote start on this year of truck, or are these universal type remote starters only for newer vehicles?
maybe
slytat is offline   Reply With Quote
Old 12-21-2006, 12:04 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: remote start
maybe
You can do it, when I installed them before I used an actuator on the throttle cable to pump the gas so it would start. This was 8 or so years ago though, maybe there is a better way of doing it now.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-21-2006, 12:56 PM   #3
Blackstone
Blackstone's Avatar
Re: remote start
It probably could be done, but I wouldn't expect it to be reliable on a carburated engine. Unless the engine is perfectly tuned, it's best to have a human element involved to control the gas pedal.
Blackstone is offline   Reply With Quote
Old 12-21-2006, 10:16 PM   #4
magnethead
7000 #'s of american IRON
magnethead's Avatar
Re: remote start
That's what I was thinking, A servo or something would have to be put on the throttle linkage.
magnethead is offline   Reply With Quote
Old 12-21-2006, 10:33 PM   #5
SSC's76
No No
SSC's76's Avatar
Re: remote start
There's plenty of them in stock form do do the trick!
AC compensator or Anti Diesel solenoid can be actuated with one of the acc wires from the remote start unit most give directions on which wire to use. The only problem like mentioned above is the choke and fast idle being dead on. I had one in my 82 firebird I also had it working perfectly with my Holley carb but the remote start unit got to be too much of a hassle. You have to activate it with a switch every time you turn the car off. If you dont you need to hold the button down for X time for it to bypass. Usually by the time it by passed you were at the car since you had to be in range of the transmitter to get it going in the first place. It got old real fast and all the extra wires under the dash were annoying.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 12-29-2006, 10:08 AM   #6
86swb
Born a Chevy Man
86swb's Avatar
Re: remote start
Sounds like more trouble than it is worth to me. I know when I first get into my truck ('86) I have to pump it a time or two before it will start. (Old school)
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 12-29-2006, 11:46 AM   #7
HotRod73
HotRod73's Avatar
Re: remote start
what about on a 87 with tbi?
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
