Old 12-21-2006, 02:29 PM   #1
bodyman9174
Towing
Hey all I have a 71 c10. I want to make this truck into my everyday truck. I have a 12ft trailer that i will be pulling with it. Some times with a camaro on it. The truck has a 350/350. What should I do to make this truck able to tow. I was thinking heavy duty springs, with bags or air shocks.Any help would be great.
Will not be towing all the time just now and than maybe 4 or 5 times a year
bodyman9174 is offline   Reply With Quote
Old 12-21-2006, 02:31 PM   #2
ClassicRedneck05
ClassicRedneck05's Avatar
Re: Towing
i have a friend of mine with a 67 that does the same stuff but all he did was put on a tow packae for his hitch and then put them heaveduty
air shocks on it
ClassicRedneck05 is offline   Reply With Quote
Old 12-21-2006, 03:19 PM   #3
truckdude239
truckdude239's Avatar
Re: Towing
its is a coil rear or leaf spring?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-21-2006, 03:22 PM   #4
ClassicRedneck05
Re: Towing
He converted his over to a Leaf mind ie a leaf as well i have a 72 GMC with a fron end chevy converson done and i have coil up fron disc brakes and read drums with leafs in the back i have the air shocks on my rear and theres time i care some good loads and have no problem u may be able to just buy some harder more heay springs i know they make them
Old 12-21-2006, 10:52 PM   #5
bodyman9174
Re: Towing
it has coil springs. I think I'm going to go with HD springs and air shocks.
Old 12-21-2006, 11:18 PM   #6
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: Towing
sorry to hijack :tj: but was wondering, is it better to tow with coil springs or leaves?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 12-21-2006, 11:24 PM   #7
ClassicRedneck05
Re: Towing
Leves are smoother
Old 12-22-2006, 03:35 AM   #8
truckdude239
Re: Towing
leves are smoother towing but normal riding around coils are better
David fuller
2000 Tahoe 5.3l 378
Old 12-22-2006, 04:17 AM   #9
72LoBurb
Yup, I'm comp-useless
Re: Towing
If you were to use urethane bushings in the rear suspension (trailing arms, and panhard bar) that should solidify the sway that you feel with coils.
I'm not sure if helper bags are specifically made for 67-72 trucks, but where there's a will, there's a way.
72LoBurb is offline   Reply With Quote
Old 12-22-2006, 04:25 AM   #10
chevguy7
chevguy7's Avatar
Re: Towing
I can't imagine that you would have any problem pulling that around. Is the camaro a show car or race car or something?
chevguy7 is offline   Reply With Quote
Old 12-22-2006, 10:00 AM   #11
SCOTI
SCOTI's Avatar
Re: Towing
12ft? No Camaro is gonna fit on that one .
I use my 68 short-fleet to pull my 18ft steel floor car hauler. The truck is lowered @ least 5/7 but I have air-bags to adjust the height back up when the load is added. I only tow something every now & then but use the trailer regularly for moving other 'stuff' (funny how many friends you have when they know you have a trailer).
I upgraded to disc brakes up front & made sure the trailer has working brakes as well cause a 1/2 ton truck isn't going to stop a loaded trailer itself. Other than those upgrades, swapping to urethane bushings is a good idea & adding a front sway bar helped too.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-22-2006, 10:42 AM   #12
bodyman9174
Re: Towing
It might be a 14 ft can't remmber. I do know when my car is up there the back wheels are about 5 or 6 inch from the back of the trailer.
Well i would not really call it a show car but i have won some first places for my painting i did. (at camaro shows) I buy cars every now and than and fix them up and sell them so need the trail for that more. And for just hualing around crap. I have disc brakes on the truck.
thanks all
Old 12-22-2006, 10:49 AM   #13
gator2511
gator2511's Avatar
Re: Towing
I tow my 25' 6000 pound travel trailer with my 72 K10 with no sweat. Of course the trailer has electric brakes and I have a good brake controller and a weight distributing hitch. Its amazing how little it drops with the trailer tongue weight on it. ( I'm not gonna tow it again until I resolve my truck brake gremlins)
gator2511 is offline   Reply With Quote
