Old 12-21-2006, 03:55 PM   #1
short step
steering stops/air bags
what do u do with the steering stops bump stops when u use air bags,remove them or shorten them to get all the drop u can
bob
short step is offline   Reply With Quote
Old 12-21-2006, 04:09 PM   #2
thekid54
Re: steering stops/air bags
Most people remove them, that's what I did.
thekid54 is offline   Reply With Quote
Old 12-21-2006, 04:57 PM   #3
action
Active Member
action's Avatar
When removed how much more drop do you get when aired out?
Jack
action is offline   Reply With Quote
Old 12-21-2006, 05:15 PM   #4
pharcyde05
pharcyde05's Avatar
RULE # 1 AIRRIDE HANDBOOK if it gets in the way cut it off
pharcyde05 is offline   Reply With Quote
Old 12-22-2006, 01:16 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Drill out the spot welds. Chisel the brackets off. Grind the surface clean. Repeat on other side.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
