long to short
Im cutting down my box so i need some dimentions from you lucky guys with real shortboxes. how much in frount and behind the wheel wells. thanks im going to cut 12" out of the frame and another 8" on the back.
Re: long to short
If I understand correctly, Ii think it's the same out of the bed sides as well. 12" in front of the wheel, then 6 or 8 out of the back.
Re: long to short
i think you take the same out of the box as you would out of the frame.
Re: long to short
Insert Title Here
Re: long to short
Heres what I got
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Re: long to short
Thanks alot 1loC10 that relly helps.
Designated A-hole!
Re: long to short
http://67-72chevytrucks.com/vboard/s...hlight=shorten
This might help.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Out of the carpool lane.
Re: long to short
I would advise you to cut 6" out of the back. Mine was cut 8" and I think it's too short. You can always cut another inch out if needed VERY easily, but it's MUCH harder to put it back.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Re: long to short
I will get some measurements of my shortbed 4x4 in a minute to see if they are the same as 1LoC10s
Re: long to short
Ok,I took these measurments along the body line on the lower half of the bed.Not exact but gives you an idea of what you need.
27 and 3/4 " from front of bed to wheel opening along bottom body line About 24 and 3/4" from wheel opening to back of bed About 3 and 3/4 " from back of sidemarker to back of bed Last edited by 1969k10stepside; 12-22-2006 at 12:29 PM. |
#11 | |
Insert Title Here
Re: long to short
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 12-22-2006 at 12:45 PM. |
Re: long to short
hmmm 2 short beds two different sizes.
i'd measure from the bottom of the wheelwell that's prolly gonna be the best. i'm glad someone asked this cause i'm about to do it to a lb i've got too.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
#13 |
Re: long to short
Pardon the fact you cant read the measurements but they are in my other post.Red lines are where I took the measurements.Here is where I measured it:
#14 |
Insert Title Here
Re: long to short
mine is the exact same.. I was stumped for a second, but I measured at the body line and its the same as Dustin
#15 |
Insert Title Here
Re: long to short
Here this should cover all bases..lol
#16 | |
Re: long to short
With all those measurments a good shortbed should be able to be made. Last edited by 1969k10stepside; 12-22-2006 at 01:03 PM. |
#17 |
Re: long to short
thanks alot guys thats helps me so much. up here in alberta canada iv only ever seen 2 shortboxes.
#18 |
Re: long to short
No problem.
#19 | |
![]() Join Date: Feb 2004
Re: long to short
$350 for an original short bed truck what a steel
![]() Too bad that I didn't find one like that Quote:
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#20 | |
Re: long to short
![]() Last edited by 1969k10stepside; 12-22-2006 at 09:22 PM. |
