08-21-2002, 04:38 PM | #1 |
Black Magic electric fan
Only used for three weeks. Brackets have been modified to fit my application, so you may need to modify these or make new moutning brackets. Works awesome, just moving to a dual fan setup. $145 shipped obo.
$189.95 in Summit $189.95 in Summit Vendor: Flex-a-lite Consolidated Product Line: Flex-a-lite Black Magic Electric Fans Material: Plastic Finish: Black Length: 18 in. Width: 4 in. Height: 16.125 in. Diameter: 15 in. Fan Up to 17 free horsepower from a fan change. Black, 15 in. diameter, plastic, puller fan By replacing your stock, engine-driven fan with a Flex-a-Lite Black Magic electric fan, you can get back up to 17 free horsepower that the stock fan was stealing. With a powerful motor and steep blade angle, the Black Magic can move up to 2,800 cfm of air--enough to cool off vehicles making 300 horsepower without air conditioning, 250 with air. The 15 in. diameter, puller-type fan has a thermostat that is adjustable from 180 degrees to 240 degrees F and a fiberglass shroud that withstands heat up to 250 degrees F. The Black Magic measures 18 in. x 16 1/8 in. x 4 in. and mounts to your radiator supports. Sold individually. |
