Old 08-21-2002, 04:43 PM   #1
fastbagged68
fastbagged68's Avatar
Question what does it take to make 73 drop spindles work on a 72
I have a freind that has a 72 and he want me to get him some drop spindles with my wholesale account butthe only thing is that the company I have my account with only sells 73 DJM drop spindles. None for the 67-72. What do I got to do to make those work with his existing disc brakes.
fastbagged68 is offline   Reply With Quote
Old 08-21-2002, 04:53 PM   #2
mooneyes
mooneyes's Avatar
your spindle should bolt right in i have 80 spindles on my truck but youll have to get 73 and up calipers not sure if the 72 rotors will fit the 73 spindle
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 08-21-2002, 05:04 PM   #3
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
I thought it took 73+ ball joints, rotor, caliper. I think someday I'll use 73+ drop spindels too, you can get them in a 3" drop spindel
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 08-21-2002, 06:01 PM   #4
67 SS
The 71-72 ball joints are different.Thers's just enough difference in the stud length that they mill not work.The 73-up ball joints will be cheaper too.
67 SS is offline   Reply With Quote
Old 08-21-2002, 06:29 PM   #5
Kid
Kid's Avatar
I put "73" up, droped spindles (Western) on m 71 by just changing the upper ball joints and outer tie rod ends, both for 73 up chevy PU. Stock 71 rotors, bearings, calipers all worked fine. Been four years now and still working great.
Kid is offline   Reply With Quote
Old 08-22-2002, 12:45 PM   #6
Fast68Chevy
Fast68Chevy's Avatar
yeah, the lower joints are same 71-up, would need the 73-up rods, may be possible to swap the 72 calipers to the 73 spindles so hoses could be left alone, maybe..
not sure, its been too long now,,
good luck
Fast68Chevy is offline   Reply With Quote
Old 08-22-2002, 02:48 PM   #7
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Thumbs up
Kid, has it right.
Upper ball joint, and outer tie rod. All calipers and roters work fine. Been there done that. A couple of times, LOL
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 08-22-2002, 03:34 PM   #8
Bagged72
Yeah, I just got done putting on drop spindles for a 73' on my 72. All that was needed, was new upper ball joints, and tie rod ends. They fit real well. I got mine from NSANE68. They are very nice.
72 Chevy Longbed. Being bagged and
shaved. To be Completed by Carcraft
03
Bagged72 is offline   Reply With Quote
Old 08-22-2002, 04:38 PM   #9
mooneyes
mooneyes's Avatar
i used 72 upper and lower balljoints with my 80 spindles with no problem...did i just get lucky?
78 caprice project
Old 08-23-2002, 02:18 AM   #10
Fast68Chevy
mooneyes4b i used 72 upper and lower balljoints with my 80 spindles with no problem...did i just get lucky?
upper balljoints n 71 and 72 are different design from 73-87, lowers are same part however, the difference from 72 to 73 uppers would be in the stud length and/or diameter, either too many threadsshowing or not enough, or loose fit into the spoindle tapered hole, or too tight fit in it,
id be worried and find out for sure that you have 71 72 uppers and 73-87 spindles, and if so then id be correcting that asap,,
good luck
Old 08-26-2002, 02:43 PM   #11
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Wink
Mooneyes, They do fit, however the stud length on the upper ball joint is too long. This in turn does not allow you to seat the cotter pin through the castle nut
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 08-26-2002, 03:30 PM   #12
Fast68Chevy
yeah, that would be the difference in the years of upper joints that i could not recall, its been too long since...
good luck
