BlahBlahBlah
headlight relays and painless
Been reading the stuff on headlight relay installs. If you install a new painless wiring harness is the relay set up still needed?
The Hammer Man
![]() Join Date: Oct 2006
Re: headlight relays and painless
hmmmmmmm good question
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
The kit for 67-72s does NOT come with a headlight relay setup. You must buy one of their headlight relay kits separately. The reason I think is because some folks might not use stock lamps. Also, the original wiring doesn't have relays, and the kit largely mirrors the circuits in the original.
TOTY 2006
![]() Join Date: Dec 1999
It is not needed, but you are still running the power from the battery to the headlight switch then to the lights.... Same as a stock harness...
