Old 12-22-2006, 03:38 AM   #1
brak
brak's Avatar
Tubular Control Arms
Does anybody make Tubular Control Arms for our trucks besides DJM?
I was looking at the DJM product, and it seems they only come with a 3" drop lower Control Arm, which would be awesome if i was trying to lay my frame on the ground, but i'm not.
I'm open to the idea of swapping to the 73 and later design, but it isn't absolutely necessary since my 72 has front discs already.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 12-22-2006, 03:43 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: Tubular Control Arms
I didn't think they used trailing arms after 72.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-22-2006, 04:11 AM   #3
72LoBurb
Yup, I'm comp-useless
Are you planning on bagging the truck? If you are Air Ride Technologies makes control arms.
If you are doing a static drop, why not look into spindles?
72LoBurb is offline   Reply With Quote
Old 12-22-2006, 08:34 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
he's talking about front arms.
I agree, go with spindles instead. dropped arms can cause ground clearance issues at times.
68C15 is offline   Reply With Quote
Old 12-22-2006, 09:03 AM   #5
krue
Designated A-hole!
krue's Avatar
Okay, I'm stupid.
www.daveramsey.com
Old 12-22-2006, 09:09 AM   #6
jkade
jkade's Avatar
Not trying to highjack the thread, but I have dropped spindles and cut springs and mine just doesn't seem like it handles as well as before. Would tubular contol arms make your handling any better? If I decide to bag mine would it be a good idea to buy a set?
jkade is offline   Reply With Quote
Old 12-22-2006, 09:35 AM   #7
Hart_Rod
Hart_Rod's Avatar
ART does (ridetech.com).
http://67-72chevytrucks.com/vboard/s...d.php?t=174330
Hart_Rod is offline   Reply With Quote
Old 12-22-2006, 11:53 AM   #8
John @ BROTHERS
John @ BROTHERS's Avatar
We carry tubular lower and upper control arms. Here is a link to each of them.
http://www.brothersonlinestore.com/p...number=LCA7200
http://www.brothersonlinestore.com/p...number=UCA7200
Remember, 10% off sale ends Dec 31
1967 Chevy Short/Fleet
1969 Chevy Short/Step
2004.5 Dodge 2500 4x4 Cummins 6spd
John @ BROTHERS is offline   Reply With Quote
Old 12-22-2006, 12:01 PM   #9
1lowdiesel
1lowdiesel's Avatar
i'd say that ride has to do with the cut springs. if your gonna bag it you can stick w/ the stockies just section your crossmember, and trim down the lower cups to about an 1" and use slam bags this way they won't balloon out and you'll get more lift.
brothers that a good price on them arms though!
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 12-22-2006, 12:24 PM   #10
bryanw1968
bryanw1968's Avatar
Agreed. Cutting the springs is more than likely the handling issue. Also, what kind of shocks are you running? Do you have a front sway bar?
I used stock spindles when I went to front disc and used lowered springs. I also installed fairly stick gas shocks and a sway bar. It handles like it's on rails.
bryanw1968 is offline   Reply With Quote
Old 12-22-2006, 12:40 PM   #11
jkade
jkade's Avatar
The shocks are stock type shocks but they are new and it does have a sway bar. I will tough it out till I get the air ride.
Old 12-24-2006, 02:00 AM   #12
brak
brak's Avatar
Those items are having script errors
" Microsoft VBScript compilation error '800a0401' "
I'm not planning on bagging my truck, which is why i'm looking for an alternative to the DJM lower arm.
I'm interested in tubular arms, because they look cleaner, and as i understand it, are lighter and stronger than the stock arms.
I'm building my truck from the frame up, and would rather do it right the first time. and considering the cost of having my old arms blasted and powdercoated, then replacing all the bushings, there's not much difference between a new set of tubular arms.
Old 12-24-2006, 02:11 AM   #13
SCOTI
SCOTI's Avatar
Stronger? Most likely.
Lighter? I don't think so.....
I weighed my ART Strong-Arms vs. stockers & they were 2~3lbs heavier.
Jkade, I question the logic that 'cut down coils affected the handling on the truck'. Trimming 1 coil off would increase the overall spring rate roughly 10~20% depending on the coils wire thickness. This increase in spring rate along w/a slightly lower COG are good for handling.
I would be more apt to say the decrease in handling is because other factors weren't optimized..... mainly the alignment. How good was (is) the alignment? How good are the shocks? And most importantly (when it comes to handling), how good are the tires?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-24-2006, 02:14 AM   #14
jimmydean
jimmydean's Avatar
I got the same error.
I am thinking about getting the ART arms for this very reason. Nobody seems to stock the front parts and when it's all said and done, it's only about $100 difference for all new vs. rebuilding.
jimmydean is offline   Reply With Quote
Old 12-24-2006, 06:55 AM   #15
ghetto_superman
ghetto_superman's Avatar
id like some lower tubular arms like the ones brothers sells.. that work with springs and not bags, but the whole "wont work with sway bar" thing scares me off... any suggestions?
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 12-24-2006, 10:57 AM   #16
piecesparts
Parts and more parts
piecesparts's Avatar
CPP (Classic Performance Products) ( http://www.classicperform.com/ )makes a tubular arm setup, as well as many other parts for the trucks. There was a big article in "Truckin" magazine Volume 32. at the end of last year on their products.
piecesparts is offline   Reply With Quote
Old 12-24-2006, 01:53 PM   #17
Fastfun
Fastfun's Avatar
I purchase a set of upper and lower tubular control arms fro CCP, but I haven't put them on yet. I also purchased their tubular trailing arms also. They are nice products and I can't wait to install them.
Fastfun is offline   Reply With Quote
Old 12-24-2006, 02:08 PM   #18
sixtysevengmc
village idiot
sixtysevengmc's Avatar
will ART or CCP control arms work with drum brakes?
I like the ol' drum brakes,there excitingly dangerous nature appeals to me (lol!)so I don't plan on swapping to disc anytime soon but would like to slam or possibly bag the front of my truck
sixtysevengmc is offline   Reply With Quote
Old 12-24-2006, 02:18 PM   #19
jimmydean
jimmydean's Avatar
You can bag your truck without converting to discs or tubular arms. Just get the Suicide Doors brackes and swap bags out for your stock springs. Without drop spindles, you can still get your truck down and have the sweet ride of air.
Even if you go with a tubular arm, you will still need to either make or buy a bracket for the top. My front disc kit was $550 and I would have rather done that before even thinking about tubular arms.
Old 12-24-2006, 04:16 PM   #20
sixtysevengmc
village idiot
my concern would be the extreme angle of the upper ball joint at the upper control arm since the drive ride height will be considerably lower than stock,not to mention alignment issues.I'm assuming tubular control arms would fix both problems.
Old 12-24-2006, 04:51 PM   #21
SCOTI
SCOTI's Avatar
The BJ angle would be better than a stock arm. But.... when trying to get really low & airing the truck out, they will still be close to or in a bind w/o swapping to some dropped spindles (which they don't make for drum brakes).
You could always swap the upper arms side to side & flip them over for a less aggressive BJ angle @ full drop. There will need to be some 'clearance' work on the upper a-arm mount & the arms themselves, but both are easily accomplished @ home w/a small grinder.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-12-2007, 05:21 PM   #22
ghetto_superman
bringin it back.... does cpp make lower arms that accept a factory sway bar(bolted right to the arm, not linked), coil spring and not a bag? and not an arm that lowers, as ive heard that lowering arms conflict with dropped spindles, which i also have. cause thats what i want. if not. could someone please direct me to somewhere that does thanks!!
-Mike
Old 01-12-2007, 05:27 PM   #23
shifty
Questionable
shifty's Avatar
CPP makes them, and they look to be excellent quality. There was a huge writeup and install using all tubular CPP products in one of the two classic truck mags over hte past couple of months.
CPP sells a swaybar to go with their setup. I'm telling you - I called these guys - they will not hesitate to lead you in the right direction, great tech help over the phone. I highly recommend calling them if you have questions.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-12-2007, 06:51 PM   #24
ghetto_superman
ok. so i know who ill get the arms from then. but just to clarify, i cant use my junkyard 73+ 1 1/4 bar cause the mounts are different? i would really like to not have to dish out more $$ for if a bar if i already have one... thanks for the help!
Old 01-12-2007, 06:55 PM   #25
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by Hart_Rod View Post
? for ya, can you still run a stock swaybar with that set-up? or just a aftermarket?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
