Old 12-22-2006, 06:20 AM   #1
krue
Designated A-hole!
krue's Avatar
Truck tilt/van tilt ???
Is the turn signal switch the same between the truck tilt and van tilts? May be easier to swap ts switches than modify the van tilt I just scored.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-22-2006, 10:25 AM   #2
72dually
72dually's Avatar
Re: Truck tilt/van tilt ???
Should be the same, other than the harness connector, and the hazard knob
If you need either, let me know. I have a few in storage. Could send you a freebie
70 GMC shortbed fleetside with a 72 chevy costume
72dually is offline   Reply With Quote
Old 12-22-2006, 04:13 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
they are the same, but the hazzard switch and plug on teh van unit may be the newer style... the replacement parts are all like the later van unit
Old 12-22-2006, 09:18 PM   #4
krue
Designated A-hole!
krue's Avatar
That's good. I'm not too worried about it being "correct", just want everything to work. How hard would it be to get the wires out of the flat connector and put them in the curved one?
www.daveramsey.com
Old 12-22-2006, 09:19 PM   #5
Longhorn Man
not very hard at all, small poker... think, dental tool.
Learn on the broken unit first.
Old 12-22-2006, 10:35 PM   #6
krue
Designated A-hole!
krue's Avatar
Gonna give it a try anyways. Got a non tilt column I don't plan on using for a spare. Connector should be the same. Thanks Andy.
www.daveramsey.com
Old 12-22-2006, 10:43 PM   #7
71swb4x4
71swb4x4's Avatar
I used a toothpick to depress the connectors on mine. I had to shave the toothpick down a bit, but depress the little metal tab, and pull it out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-22-2006, 10:45 PM   #8
72dually
72dually's Avatar
Yeppers, longhorns correct
Old 12-22-2006, 10:46 PM   #9
krue
Designated A-hole!
krue's Avatar
Thanks guys. This place rawks.
www.daveramsey.com
Old 12-23-2006, 09:44 AM   #10
Krue, I have the tilt pin tool thing. Just load them up and come on down if you want. We'll rip them apart. Besides, I can watch and learn so I can do mine
Old 12-23-2006, 07:11 PM   #11
krue
Designated A-hole!
krue's Avatar
I may holler at you next week some time Bill.
www.daveramsey.com
Old 12-23-2006, 09:17 PM   #12
I'm off Tuesday and Friday, so holler on bud!! I'm changing out trailing arm and panard bushings.
Old 12-23-2006, 09:21 PM   #13
krue
Designated A-hole!
krue's Avatar
May come down there Friday? I wanna dig around in Berry's while I'm there.
www.daveramsey.com
Old 12-23-2006, 09:22 PM   #14
Works for me!!
I may even have enough money to get something at Barry's
Old 12-23-2006, 09:25 PM   #15
krue
Designated A-hole!
krue's Avatar
May depend on whether I can find a babysitter for the boys.
www.daveramsey.com
