Old 12-22-2006, 03:10 PM   #1
424shee
gmc to chevy parts?
I'm going to the junkyard tomorow to get a coil setup and wanted to get a list of everything I needed panhard bar ,trailing arms and what else do I need?I can't afford the rearend right now,but can I somehow use mine or do I need to get the rearend also?
424shee is offline   Reply With Quote
Old 12-22-2006, 03:29 PM   #2
jimmydean
jimmydean's Avatar
Re: gmc to chevy parts?
You don't need to change the rear axle if all you're doing is going from leaf to coil.
jimmydean is offline   Reply With Quote
Old 12-22-2006, 03:46 PM   #3
424shee
for what reason would I need to change the rearend?I plan on doing an airbag setup.
Old 12-22-2006, 06:08 PM   #4
jimmydean
jimmydean's Avatar
You won't need to change the rear at all. The U Bolts hold the rear to the trailing arms and the air bags will mount to the stock spring location on the trailing arms and to the frame.
Since you are going to run bags, just get new U Bolts for the rear and shock relocators too. New U Bolts are like $20 and I got a shock kit that came with 4 shocks and relocators for the back for $150.
You will need a longer panhard bar for bags, so don't bother with the stock one.
Old 12-22-2006, 08:09 PM   #5
XXL
Seņor Member
XXL's Avatar
I'm not sure that's correct. I believe the OP has a leaf rear right now, which means he's got different rearend perches than would be on trailing arm rearend.
OP, the perches for trailing arm rear suspension can be had from lots of sources. I'll look for a link.
XXL is offline   Reply With Quote
Old 12-22-2006, 09:42 PM   #6
424shee
thanks guy's.I just wanted to make sure I got everything I needed when I go their tomorrow morning.
