Old 12-22-2006, 03:48 PM   #1
ClassicRedneck05
ClassicRedneck05's Avatar
Steering Stabilizer
has anyone ever seen Steering Stabilizers on 2WD trucks?
http://store.summitracing.com/partde...9+4294908213+0
ClassicRedneck05 is offline   Reply With Quote
Old 12-22-2006, 03:54 PM   #2
bryanw1968
bryanw1968's Avatar
Re: Steering Stabilizer
Nope.
bryanw1968 is offline   Reply With Quote
Old 12-22-2006, 04:05 PM   #3
BarryB
BarryB's Avatar
Yeap, I have one on my daily driver. And it is factory.
BarryB is offline   Reply With Quote
Old 12-22-2006, 04:08 PM   #4
ClassicRedneck05
can u tell any differance with it? could you post pics?
Old 02-01-2012, 01:31 PM   #5
bucannon
Salty Sailor
bucannon's Avatar
im curious if this does make a difference
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 02-01-2012, 01:52 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have seen 'em on 2WD rigs, but rarely. I have one on my K20.... but I kinda question their benefits. If you have problems, they'll help mask the problems. If everything is good, a steering stabilizer is probably not necessary. Just my 2 cents worth....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-01-2012, 02:56 PM   #7
6772owner
Gearhead
6772owner's Avatar
I have a Superlift steering stabilizer on my 72' C10 that I installed when I worked at a 4wd shop. I mostly did it just to have one to show and because the cost was cheap. I dont really know how much it helps, but at the time I had very large (32") all-terrain tires on the truck and I felt it couldnt hurt. I can post up some pics of it if you need/want some, I dont have any on my work computer.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 02-01-2012, 05:35 PM   #8
bucannon
Salty Sailor
bucannon's Avatar
Cool Re: Steering Stabilizer
yea if you could post pics that would be cool.
but you said you didnt notice any real difference?
Savannah, Georgia
Old 02-01-2012, 05:46 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Not aimed at me but I'll reply anyway.... I have run mine with and without a SS. In all honesty, the only difference with it installed is the steering takes a wee bit more effort, no doubt due to a lil friction (or resistance to moving) within the SS. No shake rattle or roll going down the road without it.
- Mike -
RIP El Jay
Old 02-02-2012, 10:37 AM   #10
6772owner
Gearhead
6772owner's Avatar
Honestly I agree, Im not sure how much difference it made/makes, my steering box was very very worn out at the time so it helped "tighten" up the steering a bit. Now that I have a new steering box Im not sure that it is doing much, probably just helps with the feed back to the wheel on wash board/grooved roads.
I didnt have a chance to take any new pics, but here are some older ones that give the general idea. The bracket on the drivers side uses one of the steering box bolts and the other one just u-bolts to the center link.
Old 02-02-2012, 01:26 PM   #11
bucannon
Salty Sailor
bucannon's Avatar
okay, i replaced my tie rods idler arm and pitman arm and my steering is still loose, so im assuming my box is worn out as well. i might have to invest in a steering stabilizer. im also running 35 inch tires now
Savannah, Georgia
Old 02-02-2012, 01:32 PM   #12
webfoot
Have you inspected/replaced the rag joint?
On a side note, on my K20 I recently discovered another source of slop, and that is when one of the nuts mysteriously backs off of the LH u-bolt which holds the leaf springs to the front axle. In low speed/high resistance turns the steering arm just pushed the whole axle back rather than turning the wheel.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 02-02-2012, 01:50 PM   #13
bucannon
Salty Sailor
bucannon's Avatar
ive never heard of a rag joint, is it in the steering column?
Savannah, Georgia
Old 02-02-2012, 01:55 PM   #14
webfoot
It is the rubber disc that attaches the steering shaft to the steering gear.
-me
Old 02-02-2012, 02:03 PM   #15
bucannon
Salty Sailor
bucannon's Avatar
would it be a Steering Coupling Assembly?
im looking on RockAuto's website now and dont see "rag joint"
Savannah, Georgia
Old 02-02-2012, 02:07 PM   #16
webfoot
one in the same, rag joint is gearhead speak.
They probably sell a rebuild kit in the Help! section of your favorite auto parts store.
-me
Old 02-02-2012, 02:08 PM   #17
davepl
davepl's Avatar
FWIW, my '75 Monte Carlo had one from the factory, so they're by no means limited to 4WD vehicles. No idea if they came on our trucks, however:
Section 6.865 of the parts book - "Stabilizer Unit - Steering Anti Shimmy" is listed ONLY for 4WD and only for Blazer (K).
davepl is offline   Reply With Quote
Old 02-02-2012, 03:04 PM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If a new rag joint doesn't help, and your steering box is bad, you need a new box a lot more than you need a steering stabilizer...
- Mike -
RIP El Jay
Old 07-25-2012, 05:11 PM   #19
davepl
davepl's Avatar
Ever have one of those days where you want to make sure you're not asking a question that's been asked before, so you search the archives, and you discover that you answered it yourself?
The nice thing about losing my memory is I get to meet so many new people.
I still wonder if the stabilizer does anything on a 2WD 3/4 ton, though. If they put them on Monte Carlos, they're not just for big tires.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
