12-22-2006, 04:17 PM | #1 |
The Hammer Man
turn signal cut off
my turn signal auto cutoff only works when i make a left, the right side stays on, is this an adjustment or a cleaning or a replacement? Its a Factory tilt but not sure from which year.
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
12-22-2006, 04:52 PM | #2 |
Re: turn signal cut off
There are 2 little springs in there, one of them is broke. I just got a new pair from GM dealer for about $2.00, might as well replace both, used ones don't last too long for me. Seems like the right side always goes first. Should be able to just remove steering wheel and replace.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
12-22-2006, 04:55 PM | #3 |
The Hammer Man
ok, thank you, i should have thought of this the first time i pulled the steering wheel, this will be the 4th time i need to pull it thanks for the advice
12-22-2006, 05:10 PM | #4 |
member #16
Here is a pic. It is the small coiled piece on the white cancelling part.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 12-22-2006 at 09:02 PM. |
12-22-2006, 05:43 PM | #5 |
its all about the +6 inches
actually the canclling cam isn't shown there, the canclling cam is the part that covers that and has a tube that goes up through the steering wheel.
12-22-2006, 08:48 PM | #6 |
Just gettin started!
its funny, mine turns itself off too soon. the left works fine but the right shuts off as soon as i start turning the wheel
12-22-2006, 09:00 PM | #7 |
Neither of mine work, I replaced the turn signal switch (which comes with springs) but never changed the cam itself. One more thing...
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
12-22-2006, 09:02 PM | #8 |
tow rig, make sure you get the correct cam for your column, the non tilt ones are goofy. The bearings dire on it.
primer, your wheel isn't centered, is it? |
12-22-2006, 11:44 PM | #9 |
well, its a crappy aftermarket, i havent payed much attention to it. I have only driven it a couple times. will straightening it out fix it?
12-23-2006, 12:31 AM | #10 |
Oh, if you go to the GM dealer, they used those same springs through 1987 IIRC. They don't look at you quite as funny when you ask for parts for a 87 like they usually do when I ask for 67-72 parts
I also went to NAPA and got a NF LF12 Loud Flasher, not really that loud, but you can actually hear it click. The last time my right spring broke, I did not notice it for a few days, and if you are driving down the road with the right turn signal on, that is just inviting someone to pull out in front of you and wreck your truck. Cheap insurance I think........
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 12-23-2006 at 12:40 AM. |
12-23-2006, 01:18 PM | #11 |
wow, I have my flasher wrapped in tape to help shut it up. I find I tend to not use them if they annoy me.
Primer, yes, straighten your steering wheel. |
