Old 12-22-2006, 04:57 PM   #1
skokie
skokie's Avatar
Type of motor mount to use
I have to replace the motor mounts in the truck and I was looking and found urethane and rubber. Which is better to use?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-22-2006, 06:16 PM   #2
skokie
skokie's Avatar
Re: Type of motor mount to use
After some digging on Summit I found these. http://store.summitracing.com/partde...0&autoview=sku
68 build thread
Old 12-22-2006, 09:12 PM   #3
72armyswbtruck
72armyswbtruck's Avatar
I think that Urethane would be better
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-22-2006, 09:58 PM   #4
crazy longhorn
Fabricate till you "puke"
Well, i do agree.....urathane is best.....but the mount shown will not fit your truck! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-22-2006, 11:27 PM   #5
Sweet72
Sweet72's Avatar
These are the ones you would want for a small block V8. They are also available in black. Too much money for me at $68. Yea, I'm a cheap bass-turd.
http://store.summitracing.com/partde...5&autoview=sku
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-22-2006, 11:58 PM   #6
skokie
skokie's Avatar
Sweet72
I checked those out and per summit those are for a 250 6 cylinder.
Found these http://store.summitracing.com/partde...0+4294925083+0
68 build thread
Old 12-23-2006, 12:03 AM   #7
Sweet72
Sweet72's Avatar
I'll be darned if they don't look like the right mounts for a SB V8. Sorry. I looked at some poly mounts a few years ago made by PST, I think, and now I can't find the company name anywhere on the internet???????
Old 12-23-2006, 12:06 AM   #8
skokie
skokie's Avatar
Maybe they are the same? Does anyone know if the 250 and the small block use the same motor mounts?
68 build thread
Old 12-23-2006, 12:12 AM   #9
st1x10
st1x10's Avatar
www.p-s-t.com is the site your looking for.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 12-23-2006, 12:49 AM   #10
Green Machine
Green Machine's Avatar
I was pretty sure they were the same, I checked NAPA and they list the 250, 292, 307 and 350 as using the same mount, 8 bucks each.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 12-23-2006, 12:56 AM   #11
skokie
skokie's Avatar
Looks like they are the same. Wonder why they list them different? Oh well.
Thanks for all the help folks
68 build thread
Old 12-23-2006, 11:30 AM   #12
crazy longhorn
Skokie, the mounts you show are for a car, but the ones that Sweet 72 show, are the proper mounts for thr truck. I 6 & SB are the same on the truck mounts......crazyL
Old 12-23-2006, 12:40 PM   #13
Sweet72
Sweet72's Avatar
That's good info...
Thanks for the link to the P-S-T website st1x10! BTW, I believe some of the Poly mounts have interlocking steel cores so if the poly tears or separates the mount won't come loose completely. Ive heard horror stories of vehicles with throttle linkage (not cable like my '72) going WOT when a motor mount breaks.
Old 12-24-2006, 02:35 AM   #14
skokie
skokie's Avatar
Thanks for the info Sweet72. Im getting the black ones http://store.summitracing.com/partde...5&autoview=sku
68 build thread
Old 12-24-2006, 12:36 PM   #15
Sweet72
Sweet72's Avatar
Wasn't nothin', but your welcome!
