Old 12-22-2006, 07:05 PM   #1
gflo383
looking for intake suggestions on 454
I posted in the other thread i started that i bought a 454. Well its from a 95 chev TBI, im ditching the TBI as suggested by many, and going with a carb.
I need an intake and carb, and i am not planning on makeing this a race engine by any means, but i would like to get as much as possible out of the midrange as i can with out cracking this engine open.
i was thinking of just getting an edelbrock carb/intake, like a 750 and a dual plain intake. anyone with experience with these parts or anyone have recomendations?
EDIT: also, after searching, i found the engine produces somewhere around 290HP and 410TQ stock.
1986 IROC-Z lS1/T56 Moser 9" 78mm Turbo
1968 C10 step side, 5.3 Maggnacharger TVS1900 6L80E
2009 CCSB 5.3/6L80 4x4
http://members.cardomain.com/gflo383
gflo383 is offline   Reply With Quote
Old 12-22-2006, 07:19 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: looking for intake suggestions on 454
edelbrock dual plain intakes are great. if your not going to use a nice qjet carb. use a edelbrock carb. if it were me i would try to stay away from a holley unless you like messing with them alot.
sounds like a great plan you got..gett'er done
rage'nrat638 is offline   Reply With Quote
Old 12-22-2006, 07:28 PM   #3
Duro5341
Duro5341's Avatar
I would go with the edlebrock performer RPM intake, and a 750 carb...providing your truck requires no emission testing
This will give you excellent mid range, and really good torque down low. Follow this up with a edlebrock cam, and lifter set, and maybe heads. You have a 454, so you have lots of down low torque, so just work on the mid range.
I would buy the carb, intake, cam, and lifters from one manufacturer, so you know all the parts will compliment each other properly, and match up.
Duro
Duro5341 is offline   Reply With Quote
Old 12-22-2006, 10:09 PM   #4
SSC's76
No No
SSC's76's Avatar
A good replacment for your TBI intake would be Weiand stealth or Edelbrock RPM. The carb choice is all up to you. A Holley is a much better carb but to each thier own.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 12-22-2006, 10:42 PM   #5
stepside454
stepside454's Avatar
since its an otherwise stock 454 I would use a regular Performer intake, not the RPM style. My first choice for a carb would be a good Q-jet. my second choice would be a Holley 750 Vac. Sec. or Demon Vac. sec.
Ive had a 770 CFM Holley on my truck for almost 4 years now....I never mess with it, infact I didnt take the air cleaner off since last March when I put a new filter in it.
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 12-23-2006, 01:28 AM   #6
gflo383
how much should i expect to spend on an intake and carb set-up?
sorry guys, im a EFI guy. I have 8 55lb injectors in my camaro, and i understand how and why they work, but a carb is like an ancient inventors work of art that seems very fragile and brittle and i dont want to touch IT! so whatever carb i buy, i want to bolt it on and start the truck. is that practicle or not?
what Qjet should i look for? and where? hahahah, im such a newb!
Old 12-23-2006, 09:29 AM   #7
stepside454
My first thoughts are, "why would he want to switch to a carb " ?
a good stock replacement q-jet would normally be fine, but a Q-jet from Edelbrock or Jet or some of the other performance suppliers may work a little better yet.
Old 12-23-2006, 11:14 AM   #8
grinch4om
dang its hot
grinch4om's Avatar
if it has peanut port heads, the best manifold is the Wieand for those heads. I put one on mine witha 650 spreadbore holley with electric choke and it is great. If I had a Q-jet when I did this, I would have used it simply because they are great carbs, but the holley works fine.The TBI was not condusive to power. the engine really woke up with the carb swap
grinch4om is offline   Reply With Quote
Old 12-23-2006, 12:42 PM   #9
gflo383
Ive been told from about 10 people to ditch the TBI. i do like EFI, any idea's on how to make that work well stepside454? im open to ideas....
now i just gotta find a SWB!! and i can get this truck goin.
Old 12-23-2006, 12:47 PM   #10
grinch4om
dang its hot
grinch4om's Avatar
EFI is great! TBI, not so great.
