Old 12-22-2006, 07:23 PM   #1
Duro5341
Duro5341's Avatar
Newbie - Exhaust questions
Hey guys
I recently baught a 1986 K10, all original, with almost no rust....211,000kms on the clock
Now I am up in Ontario, and to find one with no rust, is hard.....almost impossible
Anyways I have done a bit of work to it, and now looking into exhaust
One of the AIR pipes are leaking.......thus the more reason to buy headers
I am torn between longtubes, and short tubes.....and I want dual exhaust
Was wondering if anyone has pics of there Dual exhaust on there 4X4, both with long, and short tubes?
I am wondering how it is routed around the Transfer case....I want to go with the stock dual exhaust routing, where is exits behind the rear wheels, one on each side
Cameron
Duro5341 is offline   Reply With Quote
Old 12-22-2006, 07:29 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Newbie - Exhaust questions
welcome brother...great to have you on board..
long tube for sure spend the extra cash and get hookers. theres so many crappy headers out there.. a good set of headers will last the life of the truck.
i always use stage8 header bolts as well. never have leaks...
someone should have some 4x4 pictures for you.
your pal mark
o yea we got to have pictures of your rig
click the video in my signiture to hear some lomg tube hookers
rage'nrat638 is offline   Reply With Quote
Old 12-26-2006, 12:53 AM   #3
Duro5341
Duro5341's Avatar
Bump^^^^
Old 12-26-2006, 01:14 AM   #4
joeymarkgraf
joeymarkgraf's Avatar
Make sure you take a picture of your bracket configuration before you remove you stock headers. I purchased a pickup and had 4 mystery brackets that the guy that sold it to me took off. After buying a set of headers that fit, I set out to get my power steering back. It was a mess, but I ended up modifying the stock bracket to work.
joeymarkgraf is offline   Reply With Quote
Old 12-26-2006, 11:24 PM   #5
7387chevys
Ill try to remember to get pics of my exhaust tomorrow ....85 4x4 dauls flowtech 11500 full length headers 1.5" primaries 3" collecters (worth about 3mpg with headers and plugs{plugs werent very old 10,000miles on bosch platnums.sp? just changed them while we were there}and they only have one plug thats hard to get to )
Shane
7387chevys is offline   Reply With Quote
Old 12-27-2006, 01:29 AM   #6
aort
aort's Avatar
Here is a couple of pics of some long tube headers on an open frame. I can try to get some pics of the rest of my exhaust tomorrow.
'85 Chevy 383/700R4/205
aort is offline   Reply With Quote
Old 12-28-2006, 09:41 PM   #7
lurch115
lurch115's Avatar
long tube headers by far....they are 10 times easier to change collector gaskets if you ever have too.....and as far as a "factory" dual exahuast...the 4X4's didn't have it...i ran dual 3" on mine and just went up over the passager side of the transfer case....with 3" it was a trick because it was tight...but i've had it on since last winter and haven't had any problems
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
