Old 12-23-2006, 04:17 PM   #1
nvrforgotten52
nvrforgotten52's Avatar
hub/wheel bearing assembly
hi,
i am having a lot of trouble triying to get this hub off of the spindle on my 70 c ten. it is fron drums i have all the harware removed and the spindle nut off and it wont budge. i have tried even using a large claw puller... any ideas... the wheel bearings inside are bad but not frozen. it should come out.
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 12-23-2006, 04:27 PM   #2
el curioso
el curioso's Avatar
Re: hub/wheel bearing assembly
I installed the wheel and used it for leverage, try heating the bearing, The other way known to me is a BFH
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 12-23-2006, 08:29 PM   #3
nvrforgotten52
thanks i heated it up with the torch and used the puller at the same time and it finally came off thanks
