Old 12-24-2006, 01:24 AM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
700R4's and my old truck
OK this has prolly been hashed out a million times already.I have a SM465 in my truck ATM,and I am thinking about going with a 700R4 I have.Will the crossmember,and linkage work from a 350TH,or will I have to make up some stuff?What about the driveshaft?
Is there a one piece out of something that will drop right in?WHat works here?
Also how do I wire up the overdrive,or whatever.
I have all the stuff from a donor truck that had an automatic in it,so that is no problem.Also I have the Burb the 700 is in,both in tact.What will I need to do to make htis work out.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-24-2006, 01:12 PM   #2
BarryB
BarryB's Avatar
Re: 700R4's and my old truck
I did this swap in a Nova I used to owe. All I did was move the trans cross member back 2" so the 700 would drop right in. Oh and I had the drive shaft shortened also. Just make sure your motor is setting level after the swap. Put a level on the carb and level it.
BarryB is offline   Reply With Quote
Old 12-24-2006, 04:02 PM   #3
brak
brak's Avatar
the overdrive is easy, I prefer the kit from TCI (P/N 376600), it only takes a few minutes to install, converts lockup to vaccum activation, and allows you to add switches to lock the tranny in any gear, or prevent lockup for towing purposes.
it costs around $75.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 12-24-2006, 11:06 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Here's a web site I posted a while back that covers a lot of 700r4 stuff:
http://67-72chevytrucks.com/vboard/s...d.php?t=220252
You might want to check out the "How To Setup Your Driveline" section at the bottom also.
LockDoc
Leon
Old 12-25-2006, 01:16 AM   #5
Brainchild
Brainchild's Avatar
brak,that's what I was looking for,thanks
I'll have a look over the website in the next few days also LockDoc.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 12-25-2006, 02:41 AM   #6
brak
brak's Avatar
a couple other companies like painless and bowtie overdrives makes the kit, but the TCI is my favorite.
If you have any questions, shoot me a pm.
