Carolina Classic Trucks
c70 cabs vs 1/2 ton cabs
Are C70 cabs and 1/2 ton cabs all the same?
Seņor Member
Per another recent thread, I don't believe so. First, I believe the steering column exits the firewall in a different location. Second, someone else added that the bottom front corner of the doors are cut off, and that the floor pan is also notched there to allow for the larger tires.
I hope this helps, Kenneth
So Many Ideas, So Little Money
I believe aside from thedoor corners th firewall andfloorpan are differnt. I can't rember for sure onr 67-72s but 73+ there is a seam at the top front ofthe firewall, bothheave duty and light trucks have the seam, the piece below is differnt from there to the back bottom of the cab where th floor meets the back.
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
Currently Blazerless
C-70 series cabs are totally different than our trucks, C-40 to C-60 trucks share a cab like ours but there are many small differences, like mentioned earlier the steering column exits the firewall lower, but there is a cutout for it. And the column support behind the dash will have to be changed.
There is no lower front pillar support or lower fender brace, you can buy this in a patch panel, also the rockers are too short so you will have to replace them with regular aftermarket rocker panels. And you can mount regular doors or weld in a section for the lower front of the door. The front toe board rises at a much steeper angle which means quite a lot less leg room, these trucks also use a different heater box and it hangs lower which also takes up more room. The doghouse or recess in the firewall is much larger and deeper on these trucks and means still less interior room but a hole lot more room for about any kind of motor you can imagine. Cab mounts are the same. The area where the rearveiw mirror would mount are dfferent on some of the 2 ton cabs, kind of stamped out pads for lights and switch's for air tags and such. Most of these trucks are small back window, but if the cab was ment for a fifth wheel it got a large back window [I've pnly came across a few of these] Air conditioning was a very rare option on these trucks. And not all 2 ton trucks got cab lights, I've came across a few as big as C-60 with none. Also seen a few with the two tone paint division trim.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
registered IWATA user
heres a pic of a c5o that i came across
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
