Broken Down
How to hide my exhuast pipes
How do I tuck my exhaust up from being seen on my 71 C10 long bed I was goint to use one of these
THE ORIGINAL EXTREME DROP CENTER CROSSMEMBER But after alittle research they are not supposed to be used on long beds do to the carrier bearing. Does anyone have any ideas they can share. Thanks ![]() ![]() ![]()
kenm78 1982 Chevy 4X4 Project truck ![]() ![]() ![]() ![]() “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
Re: How to hide my exhuast pipes
Just notch out your stock one and brace it abit. I did this to mine but it is way over braced in hopes of alot of traction and a big motor some day
![]() Kevin LFD Inc. |
Broken Down
Outstanding is it better to pull that crossmember out or just notch it while still in the truck??
hey Kevin nice job on the cross member.that thing looks like it can take some abuse. Tony
![]() Join Date: Apr 2005
Kevin do you have any pics of the rear? How are you going to ge the exhaust over the rear end? I want to run my exhaust all the way out the back, but I don't think I'll have clearance with the bags all the way down. I was thinking about running them outside the frame.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
The LuvShack Garage
Yowsers, them pipes will be low, gonna be tuff to get em over the axle
with bags, do to the travel of things up and down that move, maybe it is time to consider side exit? in front of the rear wheals, or turn downs.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
I cut some 4" holes in the cross-member and welded some 4" SCH 40 pipe in the holes. I cut a 45 on the pipes ahead of time, and welded a plate to the end of the pipe and ran a plate to the side-rail. You can get a way with a smaller support to the side-rail, if you place it behind the cross-member, because it will be in tension. You will need more support on the front side like the photo above, because it will be in compression. Don't forget to leave a hole for fuel and brake lines. See attachment.
72 Cheyenne
I did the turn downs on mine. sounds great and man it shakes the earth!
